Cracked gas tank strap frame mount
Discussion in '2nd Gen Tundras (2007-2013)' started by Hanzo, Sep 5, 2021.
  1. Sep 5, 2021 at 7:38 AM
    Hanzo
    Hanzo [OP] New Member
    Went to replace my gas tank straps and install the RCI skid plate and found a bit of a problem. The frame mount where my rear gas tank strap bolts in is cracked. I ghetto rigged it for now, but has anyone had this problem and fixed it? What was the process?
  2. Sep 6, 2021 at 7:56 PM
    bingdude
    bingdude New Member
    Hi Hanzo,
    I asked the same question earlier this year. My bracket is just about rusted out. See the response from Techwrench in my question.
    https://www.tundras.com/threads/fuel-tank-bracket.82244/#post-2089546
    Bracket is part of the crossmember. One option is to get the crossmember replaced. I’ve been checking around local shops. 1st shop said they could fabricate a bracket and weld it to the crossmember. 2nd shop said the same as well but I have yet to bring it into them to get assessment. Hope this helps. I’ll post back up if i get it fixed soon. Let me know what you end up doing if you don’t mind. I have an 07 DC.
  3. Sep 7, 2021 at 5:41 AM
    Hanzo
    Thank you! That link is really helpful.
