Crank shaft position sensor location?
Discussion in '1st Gen Tundras (2000-2006)' started by russianbear, May 19, 2016.
  1. May 19, 2016 at 7:03 AM
    russianbear
    russianbear [OP] New Member
    Barrett
    Jacksonville FL
    2006 Tundra 4x4 Limited Double Cab
    I have 2000 Tundra 4.7 4x4 that wont start. Got code for crankshaft position sensor. I have looked and cant find video of a good pic of
    where this thing is on the engine. If anyone has a video or good pic I would appreciate it.
    Kappa82 likes this.
  2. May 19, 2016 at 10:38 AM
    Found this: Front of engine,lower driver side,mount on oil pump body behind crank pulley,remove skid plate under the truck to gain access.
  3. May 19, 2016 at 12:31 PM
    russianbear
    Barrett
    Jacksonville FL
    Thanks maluth, I already found it but that's exactly where it is. I couldn't believe there are so many posts on Internet that say it's in a different spot. Replaced it today and truck is running again. Here is a pic of where it is if anybody else cant find it. It is right under the pulley attached by a 10mm bolt and wire harness.
    Dracko, Kappa82 and Black Wolf like this.
  4. May 19, 2016 at 7:54 PM
    Glad to be of help. It was a slow day at work so I did some Googling. :cheers:
    Happy Trails to you!!
    Kappa82 likes this.
  5. May 20, 2016 at 7:06 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    It's very common for people to misroute the cps wiring when doing a timing belt... the serpentine belt then rips through the wires...
  6. Jul 4, 2017 at 10:05 PM
    Kappa82
    Kappa82 New Member
    Brenham Texas
    Green 01'Toyoya Tundra
  7. Jul 4, 2017 at 10:07 PM
    Kappa82
    Kappa82 New Member
    Brenham Texas
    What is the yellow with the black striped go to. I have a 01 and are there a crankshaft sensor and camshaft sensor and where are tjey???? Anyone know
  8. Jul 5, 2017 at 1:46 AM
    DOZER505
    DOZER505 Western TX
    Denny
    2014 Black Tundra Platinum
    None
    Im sure by tomorrow someone will chime in to help.
  9. Jul 5, 2017 at 5:45 AM
    Kappa82
    Kappa82 New Member
    Brenham Texas
    Thanks
  10. Jul 19, 2017 at 11:14 AM
    Phillipk98
    Phillipk98 05 sequoia
    2005 sr5 sequoia
    You may have better luck starting a new thread.
