Crankshaft Position Sensor 2007 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by HarMac23, Mar 21, 2020.
  1. Mar 21, 2020 at 10:56 AM
    HarMac23
    HarMac23 [OP] New Member
    2007 Toyota Tundra SR5
    5.7L engine. 4-wheel drive
    Hey guys my check engine light came on and the code it was giving me was for the crankshaft position sensor. Has anybody had to replace this before and how hard was it to get to and replace? Also if you know the location of where the sensor is located that would be great! Everything I have read says my truck should either not be starting or it should be running roughly. Neither of which is happening. Is it safe to drive if these problems aren't occuring?
  2. Mar 21, 2020 at 12:36 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I have, super easy. Driver side, toward the rear of the engine, 5.7l, just in front of the transmission bell housing its covered by a small aluminum piece about 3 inches long teardrop like, size 12mm if I remember correctly. Roll down there with a 10, 12, and 14 just in case.. because I don't remember. Part was about $95 at Oreilly... but be advised.. I did get this code just before my starter went out..
    HarMac23[OP] likes this.
  3. Mar 21, 2020 at 12:45 PM
    blackdemon_tt
    I'm at work at this time, and I brought my truck, if it's not raining I'll snap a pic and post it in about an hour....
    Edit: Here is a google image I used.
  4. Mar 21, 2020 at 1:08 PM
    HarMac23
    Awesome thanks man! I’ll go check it out then! I also had a cat converter bank low code. After I reset the codes and the light came back on all I’m getting is the cat converter code. I’m wondering if I have a bad O2 sensor and that kicked on the crank sensor code as well
  5. Mar 21, 2020 at 3:04 PM
    blackdemon_tt
    Yes... is it upstream or downstream???
    Having issues uploading the picture and I just realize my rear main seal may be bad...
  6. Mar 21, 2020 at 3:51 PM
    blackdemon_tt
    Black Pigtail to the top left. Between the crossmember and bell housing on the picture.. additionally I do realize the oil leak in the bell housing I was 2.5 quarts low today.. damn...
    Failure2comply likes this.
  7. Mar 21, 2020 at 10:09 PM
    blackdemon_tt
    Because my phone sucks, google drive sucks and I suck at posting links, I've attached the actual picture. That black thing in the bottom left hand corner is the cross member, the black thing on the right is the transmission. Just incase you're confuse. I took the picture from beneath the driver door, just behind the front left tire.
