Crankshaft sensor wiring diagram?
Discussion in '2nd Gen Tundras (2007-2013)' started by CarTop, Nov 11, 2022.
  1. Nov 11, 2022 at 3:29 PM
    CarTop
    CarTop [OP] New Member
    I have a 2011 Toyota Tundra 5.7L I bought a new crankshaft sensor. The plug was pulled out of the wires and the new sensor side is not color coded. I have searched everywhere for a wiring diagram. I have a blue, white and yellow wire and this is this side of my connector. Help please. IMG_0437.jpg IMG_0439.jpg IMG_0438.jpg
  2. Nov 11, 2022 at 3:38 PM
    Try here. https://www.tundras.com/threads/ultimate-tundra-wiring-diagrams-collection.81448/
  3. Nov 11, 2022 at 3:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    ColoradoTJ and FrenchToasty like this.
  4. Nov 11, 2022 at 3:51 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  5. Nov 12, 2022 at 6:18 AM
    CarTop
    I have the above linked manual. Apparently, I do not know what I am looking at because all I see under the 3URFE diagram is two wired in and one wire out. My understanding on the above is I need to put all three of these wires in then hook the other side of the sensor up. I do see the connector i have the sheet that has the number coded with it but nothing else.
    After reevaluation I have these two diagrams matched up, please let me know if I am reading this correctly. I have d3 connector and i put wires in by number so white yellow and blue in on the one side then when I plug the other half it white and blue are what passes on through? Thank you for all this. This is a great source of info
  6. Nov 12, 2022 at 6:33 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    WHat number is the connector?
    FrenchToasty likes this.
  7. Nov 12, 2022 at 6:42 AM
    CarTop
    D3 I am assuming it is d3 in that it matches the diagram and the d3 chart matches our wire colors
  8. Nov 12, 2022 at 6:54 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Welcome to the forum, I hope this helps.
    I pulled up the schematic and searched 'crankshaft' and found this.
    There seems to be another crankshaft sensor, but it has different colored wires..
    I'm guessing D3 is your connector..
    The pins of the connector are numbered in the schematic.
    1 white
    2 yellow
    3 blue L represents blue
  9. Nov 12, 2022 at 7:11 AM
    CarTop
    Thanks thats what I got just making sure.
    1lowlife likes this.
  10. Nov 12, 2022 at 10:02 AM
    CarTop
    Thank you very much she is up and running! And I learned something new. How to read a wiring diagram.
  11. Nov 12, 2022 at 10:18 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    That's great.
    Hang around the forum, there a lot of great people here..:thumbsup:
  12. Feb 4, 2025 at 6:03 AM
    Tanskim
    Tanskim New Member
    2009 crewmax
    Hi everyone, I’m having the same issue fully understanding the wiring diagram. So can I assume that the picture with the wiring order (123) is based on the backside of the connector where the wires go in?
