Creaking or cracking noise coming from the lower front end - Solved
Discussion in 'Suspension' started by TexasTundra4x4, Mar 26, 2023.
  1. Mar 26, 2023 at 6:36 PM
    TexasTundra4x4
    TexasTundra4x4 [OP] New Member
    2020 Tundra TRD Pro
    Westcott Designs Fox TRD PRO Lift Kit, BFG KO2 T/A 35's, PAC AmpPRO w/ Kenwood Excelon X802-5
    Hey everyone,
    I recently got the Westcott Designs lift kit on my 2020 Tundra TRD Pro and it was great for a couple of weeks, but now I'm hearing a lot of creating coming from the front end. Only happens when I'm driving under 10-15 mph, pretty loud.
    I'm calling the shop tomorrow where I got it installed and see if they could take a look at it, but wanted to see if anyone here has installed the Westcott kit on their Fox suspension and ran into a similar issue.
    Any insight would be appreciated. Thanks.
  2. Mar 26, 2023 at 6:50 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Can you tell which side?
  3. Mar 26, 2023 at 7:37 PM
    TexasTundra4x4
    2020 Tundra TRD Pro
    It was hard to tell, it only happens when it’s moving and it sounds like it’s coming almost from the middle below the skid plate, but that wouldn’t make sense?
  4. Mar 26, 2023 at 8:34 PM
    JimboSlice413
    Bakersfield
    Here's a tough one that kicked my butt. Its worth a look. When removing the pivot bolt from the passenger side upper, I broke a plastic harness that is held in place by a hole in the body. The plastic harness clip was rubbing against the body and making a loud God awful squeak at low speeds. If you find that broken, wrap a cloth around it and go for a drive.
  5. Mar 27, 2023 at 4:59 PM
    TexasTundra4x4
    2020 Tundra TRD Pro
    Solved!
    It turns out IT WAS the skid plate...
    Took it to Toyota for some scheduled maintenance and they didn't torque it correctly. They also stripped one of the bolt threads...
    While searching online for the torque specs for the skid plate, I came across this article that solidified my hunch:
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10181744-9999.pdf
    For future folks who run into a similar issue, here are the torque specs and a handy diagram.
    A --> 5mm hex --> 18 ft-lb
    B --> 12mm socket --> 21 ft-lb
    C --> 5mm hex --> 21 ft-lb
    D --> 15mm socket --> 38 ft-lb
    E --> 17mm socket --> 43 ft-lb
