Crew max length
Discussion in 'General Tundra Discussion' started by Chevyjlewis, Aug 10, 2019.
  1. Aug 10, 2019 at 1:40 PM
    Chevyjlewis
    Chevyjlewis [OP] New Member
    Missouri
    2019 Barcelona Red Tundra sr5 trd offroad
    Can anyone verify the length of a crew max tundra. Car gurus has a lenght of 228.9 in. I have a 20ft garage and want to make sure this truck will fit before i spend all my money. Car gurus shows my current truck at 230.2 in. And it fit . So in theory it should fit if i trust car gurus measuring. Might get it monday if my truck sells. But i would like to fit in garage
  2. Aug 10, 2019 at 2:07 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Google agrees. Best to drive home to verify.
    1RONMAN81 likes this.
  3. Aug 10, 2019 at 2:38 PM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    That’s going to be a tight fit with a few inches to spare in both sides
  4. Aug 10, 2019 at 2:51 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    You’ll fit, with about a foot to spare(ish) 229in. is very close. My garage is 20ft 4” and I fit with enough room to squeeze behind my truck when garage is closed. Tight, but fits. I also rub the top of my garage coming in, but that’s a different story.
  5. Aug 10, 2019 at 5:26 PM
    Chevyjlewis
    Missouri
    Thanks. My garage door is an extra foot tall than a normal 4 panel garage door. so i am good there
  6. Aug 11, 2019 at 4:37 PM
    jewild
    jewild New Member
    2019 Tundra Limited
    3/1 level" Real lift, 20" fuel wheels on 31"tires
    My garage is 21', your truck will fit being 19', but you'll have the nose almost against the wall and the door will have to be up to walk around it.
    I questioned the same thing and with my 3" lift and 35" tires, it's DARN close to the top of the garage door opening.
    My door is 16x7, wish I had that extra foot of height, that you have.
    That door had to be a custom order, most standard doors are 7' high.
    Enjoy.
  7. Aug 11, 2019 at 8:57 PM
    Chevyjlewis
    Missouri
    We built had the house built. We chose to go taller for the door based on exterior looks.
