Crew Max vs Double Cab
Discussion in 'New Member Introductions' started by Vistallp, Jul 23, 2020.
  1. Jul 23, 2020 at 1:10 PM
    Vistallp
    Vistallp [OP] New Member
    2011 Toyota Tundra SR5
    Hey guys I'm a new Toyota Tundra owner... I bought it used and I am now trying to buy Husky floor linets and and a gear box, but dint know how to tell if this SR5 is a Crew Max or a Double Cab trim... is there an easy way to tell?Thanks!
    YardBird and Y0TA PR0 like this.
  2. Jul 23, 2020 at 1:12 PM
  3. Jul 23, 2020 at 1:17 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Welcome from MA
    :worthless:
    Vistallp[OP] likes this.
  4. Jul 23, 2020 at 1:17 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME! If the back doors are bigger than the front doors, you have a crew max.
  5. Jul 23, 2020 at 1:18 PM
    Vistallp
    Thanks TX!
  6. Jul 23, 2020 at 1:18 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Compare Google pix of crewmax and double cab and compare your tundra.
    Outbound and Vistallp[OP] like this.
  7. Jul 23, 2020 at 1:19 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Here's a Google pic for reference...
    Boerseun, Vistallp[OP] and TOYOTRD8 like this.
  8. Jul 23, 2020 at 1:24 PM
    Vistallp
  9. Jul 23, 2020 at 1:26 PM
    Makoy339
    Super White TRD
    TRD parts
    You have a CrewMax.
    Vistallp[QUOTED][OP] likes this.
  10. Jul 23, 2020 at 1:26 PM
    Vistallp
    Looks like a Crew Max....thanks y'all for the help and all the warm welcomes! I'm very happy to be a "Tundrite"
    Black Wolf and Boerseun like this.
  11. Jul 23, 2020 at 1:29 PM
    Vistallp
    PS...I bought it to tow a new camper I've ordered....if therebare any Tundra folks who pull campers, would love to connect for tips....this'll be my first time pulling a camper...a bit nervous and want to err on the safe side...
  12. Jul 23, 2020 at 1:33 PM
    Welcome from Ohio
  13. Jul 23, 2020 at 1:34 PM
    Makoy339
    Super White TRD
    TRD parts
    You might want to check the Towing & Hauling section...
    https://www.tundras.com/forums/towing-hauling.53/
  14. Jul 23, 2020 at 1:54 PM
    Leo's first
    Groton ma
    Yep you got the best model a sweet crew max
    10TundraSR5 likes this.
  15. Jul 23, 2020 at 3:40 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    good choice!
  16. Jul 23, 2020 at 6:54 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  17. Jul 24, 2020 at 3:34 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania. Great choice in color!
  18. Jul 24, 2020 at 6:20 AM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    Welcome from Virginia! Enjoy that rear window that goes all the way down.
  19. Jul 24, 2020 at 6:40 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  20. Jul 24, 2020 at 7:33 AM
    PJR202
    PJR202 New Member
    I don't own one, but I've pulled one 5 times and I've been visiting friends, gone to events, etc, at campgrounds more times than I could begin to count. I'm paranoid about breakdowns or getting boxed in somewhere so these are my basic rules.
    --learn the hookup and unhook/leveling process inside and out, and store your chains/stabilizers, cotter pins somewhere safe and secure.
    --Check your tires. Check the pressure, look for cracks, damage, etc. Possibly the worst situation you can be in is to be changing a trailer tire on the driver's side along the interstate. And if you have to do it, call for courtesy patrol so they can set up behind you with flashing lights.
    --Go to a parking lot and practice (if you don't already have experience with trailers--I didn't). Learn your turning radius, gauge your wheel cutting points so you can finesse the trailer in there. stuff like that. Remember your wheel turns are opposite of how you would when driving something without a trailer. At some point farther into the process your wheel turns will be the other way, but getting started they'll be opposite. some people like to just hold the wheel at the bottom so that the direction your hand moves is the direction the tail of the trailer moves.
    --Test and adjust the trailer brake before you go. Your truck has great brakes but they'll get hot in a hurry. Go slow. I always kept it at 60mph (pulling a 25ft camper with an 05 Ram hemi). You aren't saving a ton of time by running it 70+. Aat 60-65 you'll save some gas, but most importantly, you can stop the rig faster. When possible, let the truck slow by coasting. This is a bigger deal for off-ramps. You don't want to be hammering the brakes in that scenario.
    --Plan your stops. If you're burning a full tank of gas on the trip, know the places you can stop and will have room to get the rig in and out without much hassle. The last thing you want is to hit a busy gas station. I also like to take the truck out from the campground solo and fill the tank before leaving. Saves you some hassle. Plan your route and know several places you can stop. I'm sure there are resources for this online. When you do hit a gas station or truck stop, stop once you enter and decide where you're headed and that you have a clear entry and exit. Have someone go snag the pump for you ahead of time so no vehicles sneak in while you're getting going.
    --Verify the length of the campsite vs your trailer, tongue, AND truck length. If you cut it close it doesn't always work out. I've seen some janky setups at campgrounds because people either didn't get realistic about their setup, or were so desperate for a spot they just took whatever they could. If you want to get REALLY PJR202 about it, you can look at overhead views of the campground and see if there are trees opposite your site. Those can get in the way of the nose of your truck when backing in.
    --------DO NOT BE AFRAID (or too proud) TO ASK ANOTHER CAMPER FOR HELP. PEOPLE LOVE THAT SHIT. FOR REAL.
    Most of these guys and gals have pulled a camper a million times and are very knowledgeable and sympathetic to the needs of another camper. It's almost a family environment.
    My ego is very small, so I've used a guide every time I've backed that sucker up. They're helpful for getting you dialed in just right to maximize the space beneath your awning, and VERY valuable for keeping an eye on kids and walkers that are complete morons and think it's fine to just walk behind the camper or past the nose of your truck. I did this in the dark one time with my dad spotting. It was infuriating. I had people going off the road because I was blocking it, and walking DIRECTLY BEHIND the camper as their alternate route! After we got it done and set up, a guy came over and said "That was an awesome job backing that thing in. It was nuts out here."
    Which brings me to another critical piece of advice.
    --Plan ahead so you aren't arriving in low light conditions. Leave LOTS of time.
    And another
    --Understand your plumbing situation. Make sure you know how to empty your tanks (opening them up and driving down the road is easiest! JK) at the dump station (or how to connect if the site has a sewer hookup). BRING DISPOSABLE GLOVES and sanitizer. My dad freaks out if he gets poo on his hand or shoe. Cracks me up because he's not that type of guy normally. There's just something about someone else's feces that really gets him..haha.
    OK that's all I can think of at the moment.
    Leo's first likes this.
  21. Jul 24, 2020 at 10:27 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
