Cruise control shifting problems
Discussion in 'Performance and Tuning' started by tjacob95, Nov 13, 2024.
  1. Nov 13, 2024 at 1:39 AM
    tjacob95
    tjacob95 [OP] New Member
    2014 toyota tundra limited
    Has anyone else experienced this when going up a hill my truck will downshift and rpms will raise to maintain speed but once leveled back out my truck should go back into overdrive and rpms should drop back down, but mine will stay in that high rpm range and not go back down almost like its stuck in that gear anyone else experienced this? Video for referencehttps://www.reddit.com/r/ToyotaTundra/s/nmITSPgpRX
    HulkSmurf14 likes this.
  2. Nov 13, 2024 at 1:41 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Occasionally, yes. Not often enough to bother me to the point that I want to make any more tuning adjustments though. I’ve got it so it shifts so well the other 99.4% of the time, I’m a little afraid to tinker…
    For grins, try driving in S6 and see if it does the same. Mine only does it in D.
    There are different tuning tables for these, but not some specific things aren’t tunable in each condition.
  3. Nov 13, 2024 at 2:10 PM
    CMikeB
    CMikeB New Member
    Be careful using 'S' Mode! You run the risk of actually being able to control when your transmission shifts! You'll be able to choose how long to stay in a particular gear. Eliminate the constant downshifting that prevents the Torque Converter from locking up, so heat build-up is reduced! You'll also reduce wear on your brakes and increase the overall enjoyment of driving your truck!:D
  4. Nov 13, 2024 at 2:22 PM
    tjacob95
    So this is normal? I thought only mine did it.. thought something was wrong with my truck
  5. Nov 13, 2024 at 2:23 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I have been using "S"equential mode in S6 when on long trips...you should be fine...the reason why I use this tactic is precisely the reason you're asking about...it's annoying and doesn't make sense to me...but S6 rocks and I even monitor transmission temperatures and it does nothing that makes me concerned...
  6. Nov 13, 2024 at 2:45 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Normal. And that can happen quite a lot in driving and especially on cruise control depending on grade, load and if you are running heavier tires/wheels. That constant shifting back and forth is not good, so you would be better in S mode when you are in conditions when it happens.
    HulkSmurf14 and FrenchToasty like this.
  7. Nov 13, 2024 at 2:50 PM
    tjacob95
    Im j
    ust talking about the getting caught in gear
  8. Nov 13, 2024 at 2:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Understood...it's not uncommon...the work-around is using S4-6 (unless you're a column shifting transmission)...
    CMikeB likes this.
  9. Nov 13, 2024 at 3:15 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Column shifter has a toggle switch for s mode too.
    CMikeB and HulkSmurf14[QUOTED] like this.
