Cruising range for 38 gal tank?
Discussion in '2.5 Gen Tundras (2014-2021)' started by JDHolliday27, Jan 22, 2018.
  1. Jan 22, 2018 at 10:38 AM
    JDHolliday27
    JDHolliday27 [OP] New Member
    2018 CM
    I have a 2018 Tundra CrewMax with the upgraded 38 gallon fuel tank. When I left the dealership with a full tank, the cruising range display on the MID was showing just under 600 miles to empty. However, ever since then when I fill up - I'm only getting in the range of 470-490 miles? I typically fill up before the fuel light comes on, but still doesn't make sense the huge difference in cruising range. I also only see the tank fill up to about 28-29 gallons...does the reserve go that far after the range hits 0?
    Looking for input from others who have the 38-gal tank.
  2. Jan 22, 2018 at 10:46 AM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Mine consistently shows around 420 after a fill-up.
    GlobalGuy and Y0TA PR0 like this.
  3. Jan 22, 2018 at 10:46 AM
    Unlimited
    Unlimited New Member
    2017 Tundra Crewmax Limited TRD Offroad
    TRD dual Exhaust, TRD Pro Skid Plate, TRD CAI, Demello Hybrid Sliders, Bilstein 6112/5160, Total Chaos UCA, Toytec rear Shackle lift @ 1.5", SCS Ray10 18" with spare, Cooper STT Pro 295/70r18 with spare, Extang Solid Fold 2.0 Tonneau, KB Voodoo Hi Rise Crossbars Oh Sh!t handle add
    It is pretty high straight off the lot, but levels out to somewhere in the 400's until it knows the driving habits. Keep in mind there is something like 8-9 gallons left in the tank when the light comes on as well. There's a pretty good thread with people's experience if you search the forum; or someone will probably post it.
  4. Jan 22, 2018 at 10:52 AM
    Noodle
    Noodle That Guy
    Files creek
    2016 Tundra Limited TRD DC Inferno
    Wvmoonshiner likes this.
  5. Jan 22, 2018 at 10:55 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Learnt my habits. Yesterday’s fill up read 460.
  6. Jan 22, 2018 at 10:59 AM
    JDHolliday27
    2018 CM
    Thanks for the replies. Figured it was a learning system and adjusted after my average MPG leveled out, but wanted to be sure. Really wish we could get close to 600 miles per tank though. Good to know about the reserve capacity as well
  7. Jan 22, 2018 at 11:14 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Yep. Mine also started at 600 and being in CO settled at 420.
  8. Jan 22, 2018 at 11:23 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    Anytime you remove the negative cable for awhile the "Distance to Empty" meter will reset and I think the computer automatically assumes you will average the best the truck would be capable of. Say, 17mpg or so. I've done it twice now and each time it goes back into the 600+ range and after about 5 tanks or so it goes back to my normal 450-475 to empty range. I run it from there down to 0 most of the time. Even going to actual "0" I only get 30-31.5 gallons back in depending on my driving. You would have to drive awhile on "0" where it switches to a "Low Fuel" display on the gauge to truly get near the said 38 gallons. By then the computer will be screaming at you.
    My '11 with the 26 gallon tank was no different, it just carried less fuel. I typically only got 20 gallons back in on that truck when going to 0.
    It's a 38 gallon "capacity" tank but not "usable" per se. Still, I'll take the 38 over the 26 gallon tank any day. I only got about 320 per tank with my old one.
    TheBeast and TXMiamiFan like this.
  9. Jan 22, 2018 at 11:32 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    It’s a good number 420 :rasta::D
  10. Jan 22, 2018 at 12:00 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Mine read 416 every time, without fail
  11. Jan 22, 2018 at 12:48 PM
    nodak67
    nodak67 New Member
    JR
    typically Toyota reserves 10% of the tank capacity as a reserve (across all models) that when the gauge show zero miles you have about maybe 45-60 miles to actual empty (across all models). but as a warning, I wouldn't run the fuel system completely dry as that may cause issues.
  12. Jan 22, 2018 at 1:02 PM
    Sunnier
    Sunny
    San Diego, CA
    Absolutely don't rely on much of that "reserve" fuel. I've read all over this site that our Tundras fuel pump is in the tank and stays covered by that "reserve" fuel that's not registering on your gauge. It's some kinda by-design thing, and depleting that fuel could damage the pump. Sorry that's not scientific sounding; but wanted to quick caution you about any assumption that you can cruise on blithely after your gauge shows empty.
    831Tun, TXMiamiFan and T500 like this.
  13. Jan 22, 2018 at 1:04 PM
    nodak67
    nodak67 New Member
    JR
    yeah forgot about that, the fuel pump is lubed by the fuel in the tank, that was the issue I think I was referring to. couldn't remember at the time. :)
    TXMiamiFan and Sunnier[QUOTED] like this.
  14. Jan 22, 2018 at 1:36 PM
    Noodle
    Noodle That Guy
    Files creek
    I’ve read that’s it also for cooling issue to make sure the pumps stays submerged and runs cooler for longevity.
    Sunnier[QUOTED] likes this.
  15. Jan 22, 2018 at 1:37 PM
    Tundra1078
    Tundra1078 New Member
    Peter
    Los Angeles
    2018 White Platinum 4x4
    TRD dual exhaust, sway bar, TRD skid plate, grab handle (future), husky liners
    Mines about 440 mile range so far.
  16. Jan 22, 2018 at 1:42 PM
    JDHolliday27
    2018 CM
    Thanks, yea I'm aware of fuel pump starvation issues if you run the tank too low. Just nice to know that there is a decent amount of range left once the display hits 0.
    Yup the fuel in the tank keeps the pump lubricated and cool. If you continually run your tank low, it can lead to fuel pump starvation issues and burn out the pump prematurely.
  17. Jan 22, 2018 at 1:43 PM
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    I have also have this issue with my pick-up. Here is what I came up with. Please keep in mind these are my findings as it relates to my pick-up. When I left the dealership I too had a range on the order of 600 miles to empty. After a few fill ups it settled around 485. So recently I decided I was going to run it to empty (Scary thought for me) but I did go an additional 40 miles past where it said I only had 2 miles left (which it stayed at for whatever reason during this test), and it still did not empty. After running this experiment I was able to put and additional 3 gallons in the pick-up bring the total to 32 gallons. In conclusion 600/15.8 is equal to approximately 38 gallons. Where as 485/15.8 is approximately 30 gallons. I have tracked my fuel usage and despite the cluster saying I get 13.8 mpg I am actually getting 15.8 mpg. I know the tank to be 38 gallons, so I concluded that cluster is highly inaccurate, but in such a way that it will allow me to never completely run out of fuel so I am ok with it. I hope this helps.
    _khaki_ and Tundra13jr like this.
  18. Jan 22, 2018 at 4:55 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Mine usually shows mid 500's DTE after I fill up the tank. Hasn't changed over the 3K miles I owned/drove the truck, my MPG average since new is about 18 (hand calculated).
  19. Jan 22, 2018 at 5:08 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Had my 18 since 20 NOV 17. Every time I fill, or top it off, the range is like 523 or something. I'll get a pic next time.
  20. Jan 22, 2018 at 6:03 PM
    Mssmith8
    Mssmith8 New Member
    2018 Tumdra Limited
    Gonna depend on you tank MPG, around town I get 420-450 pretty much all the time, but took a 500+ mile all interstate trip 2 weeks ago and avg MPG was 16.8 and had reset my trip on fill-up so around 520 on the tank and range still said about 60 miles.
  21. Jan 23, 2018 at 3:40 PM
    GoCboys
    GoCboys New Member
    TX
    2018 MGM CrewMax
    The first few tanks have been disappointing - only getting 14-15 mpg avg. After viewing your thread, decided to make her thirsty - 521 miles on 29 gal for 17.9 mpg
    Good girl!
    tAcomaPueblo and 71_340 like this.
  22. Jan 23, 2018 at 4:46 PM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    Mine is negatively very optimistic. Low fuel light means i can pass about 6 more gas stations.
    Then worry..
  23. Jan 23, 2018 at 4:47 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I hate my gas mileage but the tank far outlasts my bladder
  24. Jan 23, 2018 at 5:11 PM
    RonW
    RonW New Member
    I filled up this morning and it read 545 miles for the range.
    I'm just over 4000 miles so I don' know how much learning it has left.
  25. Jan 23, 2018 at 5:22 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    This!! When I travel, I fill up everytime I make a bathroom break.
  26. Jan 23, 2018 at 5:41 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    What did you change to achieve a 17.9 MPG average up from 14.5, what is your driving style and conditions? I am glad to see somebody else besides me gets decent fuel mileage.
  27. Jan 23, 2018 at 5:48 PM
    GoCboys
    GoCboys New Member
    TX
    2018 MGM CrewMax
    Nothing specific, have read other posts about a learning curve and/or “breaking the truck in”. Just hit the 2000 mile mark . . . . hoping that it keeps going on like this
    Yes, I know that I didn’t buy it for the mpg but it doesn’t hurt
  28. Jan 23, 2018 at 5:57 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Mine always shows 414miles for range and that's running 37" tires on a 7" lift. But I did regear to 4.88s.
  29. Jan 23, 2018 at 6:17 PM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    usually about 430 on 35's but then only holds 32 gallons when I fill up
  30. Jan 23, 2018 at 8:05 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    With the 36 gallon tank It seems like for ever between fill ups.
