Curious to know what happens when the 3rd gen battery kicks the bucket?
Discussion in '3rd Gen Tundras (2022+)' started by Asleepinthecove, Nov 8, 2023.
  1. Nov 8, 2023 at 6:45 PM
    Asleepinthecove
    Asleepinthecove [OP] New Member
    Louisiana
    2024 Toyota Tundra TRD Pro in Terra color
    This may be a stupid question but I am not mechanically inclined. I work in the medical field and this is my first truck since the age of 15. I have a new 2024 Tundra TRD pro in the Terra color and it’s my first ever hybrid vehicle. I know the Tundra IMAX Hybrid engine is mainly designed to increase the towing and tourqe for the vehicle but what happens if you keep the truck until the battery goes out. Will it have to be replaced or will the vehicle basically run like the regular V6 non hybrid if you decide to not replace the battery?
    WesternDawg, Kap1 and Tundrastruck91 like this.
  2. Nov 8, 2023 at 7:32 PM
    VikingTundra
    VikingTundra New Member
    My wife has the '22 Rav4 hybrid, and the battery was faulty (warranty). Her car sat for almost 5 months because she was away on work, and it wouldnt start or light up in the garage, but once we jumped it, it ran like a non-hybrid vehicle. It seems like all the systems worked fine, she just had the dash light letting her know there was a hybrid system fault. I would venture to guess all of Toyota's hybrids are like this since they all use the same tech. Just my anecdotal info :D
    Tundrastruck91 likes this.
  3. Nov 8, 2023 at 7:48 PM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    I still have my 2015 Toyota Highlander hybrid with 150000 miles . Thats 8 years so far .
  4. Nov 8, 2023 at 7:50 PM
    Asleepinthecove
    Louisiana
    I was thinking the same thing. Much like the PHEV vehicles now that work on the battery until they run out of a charge and then the combustion engine takes over until you can charge the battery. Most people don’t keep vehicles that long and I believe Toyota has a 15 year battery warranty if I am correct. Seems like that would be a problem for others who buy one used but it’s something I wasn’t sure about.
    RobertD likes this.
  5. Nov 8, 2023 at 7:51 PM
    luwig
    luwig New Member
    Might be a bit different as standard toyota hybrids have the motor in the rear not sandwiched between the engine and transmission.
  6. Nov 8, 2023 at 8:03 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Pretty sure I read Toyota recommends you pull the batteries once dead, and bury them deep in the ground, by a nearby stream if possible.
    MrKABC, pwpblue, Hank Hill and 19 others like this.
  7. Nov 8, 2023 at 8:07 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    lol
  8. Nov 9, 2023 at 5:55 AM
    xc_tc
    xc_tc New Member
    A dead high voltage battery is different than a slightly depleted high voltage battery.
    If the HV battery dies, the vehicle may go into limp mode and likely shows a hybrid system fault.
    The high voltage battery starts the engine via the electric motor and charges the 12V system via the DC-DC converter. There is still a conventional 12V starter on the Tundra so the engine may start normally but the dead battery is an abnormal condition that would require service.
    Orions Dad likes this.
  9. Nov 9, 2023 at 6:08 AM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    That is pretty good.
    Just curious, so now I assume that your Highlander is out of warranty (by mileage) do yo know how much it would cost to replace the Hybrid battery in your Highlander if something does happen? Have you checked to see if they are readily avaialble?
    **EDIT
    Looks like about $2,900 (less core replacement) for aftermarket battery + taxes + shipping + install
    https://www.besthybridbatteries.com/products/toyota-highlander-2014-2019-hybrid-battery
  10. Nov 9, 2023 at 7:01 AM
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    According to a quick google search Beachmont Toyota says between 2k and 8k.
  11. Nov 9, 2023 at 11:16 AM
    Hella Krusty
    Hella Krusty New Member
    Probably sell one of my children and re-up with new batteries
    hagrid and doublethebass like this.
  12. Nov 10, 2023 at 9:40 AM
    DaveE
    DaveE New Member
    2023 Platinum Hybrid, Magnetic Gray
    Not concerned. My relative have a 2006 Prius hybrid with NiMH battery, 180-200k miles and still running on original battery with no issues.
  13. Nov 11, 2023 at 6:38 AM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    There is a video on youtube, guy shows you how to remove the battery, replace the battery pack, and install it. It was way cheaper to do yourself, didnt look that difficult.
    BlueCrushSC16 and koditten like this.
  14. Nov 12, 2023 at 7:07 PM
    TundraWorkHorse
    Yes and it will be well worth it . It was the last series with the v6 tacoma engine . I think these were made in Japan ? Just a solid suv .
  15. Nov 12, 2023 at 8:15 PM
    xc_tc
    xc_tc New Member
    pretty sure all Highlanders were made in USA in Indiana. They even exported them to Australia as the Kluger. If your VIN starts with a J it’s made in Japan, otherwise made in Indiana.
  16. Nov 27, 2023 at 6:57 AM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Yeah, I believe by the time most people need to replace these batteries. There will be cheaper options or solid state batteries which would be much smaller than these. As time goes by the batteries will decrease in price generally.
    Mattedfred likes this.
  17. Nov 27, 2023 at 9:14 AM
    ArticTundra
    ArticTundra New Member
    Cold
    My Prius battery last 17 years before a cell went bad. I ordered a refurbished one and did the swap myself in about 2 hours. It's not terribly difficult. As long as you are careful.
