Custom Bed Rack/Rails
Discussion in '2.5 Gen Tundras (2014-2021)' started by atruckowner, Nov 13, 2020.
  1. Nov 13, 2020 at 9:29 AM
    atruckowner
    atruckowner [OP] New Member
    Tampa, FL
    2020 White Limited CrewMax
    Rough Country DC2 Side Steps, Rod Holders, Yakima Bike Mount
    Anyone ever built their own DIY bed rail system?
    I am looking at using T-Slot framing across the bed in two spots but trying to find the best bracket solution to carry a solid load if need be.
    Basically mimicking this design for 1/3 the cost is my objective.
    https://billiebars.com/
    The great thing about the T-slot framing is if you ever want to build a different system such as a higher overland style rack, it's modular and you can just add on to it.
    Cheers.
  2. Nov 13, 2020 at 10:15 AM
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
  3. Nov 13, 2020 at 12:04 PM
    DFirsty
    DFirsty New Member
    2016 White TRD Pro
    I made a set out of 2” square tubing and some angle iron. Less than $50 worth of supplies. The only picture I have is with the tent on and the bed loaded but I can post another of just the bars when I get home.
    -Derek
  4. Nov 13, 2020 at 3:24 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    I've got a version percolating around my noggin... more headache rack, lumber rack, canoe kayak rack than Overlander, but once I have the bed rails dialed in, it will be highly flexible for different uses.
    Like you, I'm using 8020 T-track. This is the profile I bought. It'll probably be thanksgiving before I get to experiment with the mounting.
    https://8020.net/3075.html
    If all goes well it will NOT interfere with my Tonneau, and will actually free up the bed tie down rails so I can use a cargo divider under the tonneau as well.
