Custom bracket for mounting under hood
Discussion in '3rd Gen Tundras (2022+)' started by ghunter321, Sep 7, 2023.
  1. Sep 7, 2023 at 11:46 AM
    ghunter321
    ghunter321 [OP] Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    I am trying to come up with a solution to clean up my ever accumulating relays and fuses. I purchased a fuse relay box here (https://www.amazon.com/ONLINE-LED-STORE-Waterproof-Automotive/dp/B07MR64XK1?keywords=relay+box&qid=1694111966&s=automotive&sr=1-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1) that could be mounted in the space just forward of the passenger side fuse box (see pictures). Before you say "shoulda got a switchpro", I'll mention I'm going for a strict OEM look and I dont really care for the look of the switchpro stuff.
    Can anyone point me toward someone who could help manufacture a hardware mount for this location? aluminum or steel powdercoated and all? Happy to share measurements.
  2. Sep 7, 2023 at 12:28 PM
    brutalitybob
    brutalitybob New Member
    Not sure on the argument of the look of it as who other than you is going to look under the hood at it? No matter what you add its not going to be OEM. I went with an Auxbeam switch and relay box and just VHB taped on top of the fuse box. Couldn't find a flat enough spot for mine to mount anywhere.
    KroppDuster likes this.
  3. Sep 7, 2023 at 12:34 PM
    ghunter321
    NC
    More the look on the user end with the screen and buttons. I was more hoping someone might have a source for cutting and bending the metal to fit the specs for this spot so I CAN have a flat space to mount. Theoretically, mounting holes could be slotted to have more flexibility with other boxes and could start a small business of it.
  4. Sep 7, 2023 at 1:49 PM
    99ways2die
    99ways2die New Member
    OP, I can appreciate your drive for neatness and "that OEM look" to your wiring/etc.
    I found that relay box a bit too cumbersome when I was doing all my wiring, so I simply made a 4x relay mounting bar.
    Pics below for reference and to show how I did most my my visible wiring.
    (to the point of having Toyota service dept/tech compliment my 'best aftermarket wiring we've seen so far' and not flagging it for service/battery replacement request).
    Also not a fan of switch-pro/etc modules, so the last pic shows what/where and how for most of my light switches.
  5. Sep 7, 2023 at 2:03 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I've purchased that fuse box...threw it away. Hit a pebble, hit a dip in the road, or rip out a fart and it would lose connectivity. Loose wiring, loose crimping, more of a headache than it was a solution. If it's not happening to you now.... it will later when you need it most.
  6. Sep 7, 2023 at 3:56 PM
    ghunter321
    NC
    That's a pretty clean setup too. Sounds like the Amazon part I have might not be a fan-favorite here. Do you have any links to relay brackets and fuse box parts?
    I guess it's not the end of the world if I don't use mine since the box was a birthday gift from my MIL. As long as she doesn't know I didn't use it, we should be good. :rofl:
  7. Sep 7, 2023 at 4:05 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Do want to note that it gets hot under the hood...things made of plastic not designed to withstand that heat tend to go soft - hence leading to shit not working.
  8. Sep 7, 2023 at 5:24 PM
    Nice! Where did you get those relay holders?
  9. Sep 7, 2023 at 5:24 PM
    See if PowerTrays has anything.
  10. Sep 8, 2023 at 2:49 PM
    gmotoring
    gmotoring New Member
    Orange County
    2023 Tundra SR5 4x4
    Will never install TRD branded stuff on my Truck
    Love what 99ways did, and saves $100 bucks on a Powertray spend!
  11. Sep 8, 2023 at 4:30 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I have a takotunes tray for sale if youre interested
  12. Sep 8, 2023 at 6:30 PM
    99ways2die
    Not really sure what you mean by "holders."
    What you see are:
    Hella relays (example in link; not exactly the same I used)
    https://www.amazon.com/HELLA-007794...dp/B004KEKYWQ?keywords=hella+12v+relay&sr=8-3
    Hella waterproof relay connectors
    https://www.amazon.com/HELLA-H84708...p/B000VU5ITM?keywords=hella+12v+relay&sr=8-19
    ...and they're simply mounted to a piece of aluminum stock bar, cut/trimmed/drilled to fit the install position.
    Quick note (for anyone that cares) on my switches and a case against Aux/etc switch panels:
    To the best to my knowledge they provide simple ON-OFF operation for connected devices. All my lights are wired to operate in AUTO-OFF-ON mode, hence the need and use of 3-way switches as I see fit.
    Take my light bar, for example-in AUTO it turns on with my trucks high beams, when OFF it's off no matter what, when ON (down position) it's on no matter what the truck/lights are doing.
    While switch panels serve a purpose, I need/want more advanced setup and functionality of my aux equipment, to make operation as automated as I want, or manual. My implementation may be a bit more bulky (can't beat the compact size of an Auxbeam 8x switch panel, for example)...but it is more flexible.
    ghunter321[OP] likes this.
  13. Sep 9, 2023 at 10:25 AM
    ghunter321
    NC
    Would you be willing to share the details of wiring into the high beams for auto? I’d love to get both of my light bars to come on when I flip to high beams but also retain the ability to turn them on or off too. Thanks!
  14. Sep 9, 2023 at 2:00 PM
    99ways2die
