Custom headache rack design
Discussion in '3rd Gen Tundras (2022+)' started by SilverTundra18, Feb 7, 2025.
  1. Feb 7, 2025 at 1:30 PM
    SilverTundra18
    SilverTundra18 [OP] New Member
    Jess
    2024 Silver Tundra
    I am designing a lightbar/headache rack using 1/2" aluminum. Any thoughts or suggestions on the design? Probably use an online service like xometry to laser cut and bend. Not sure on price yet.
  2. Feb 7, 2025 at 1:40 PM
    Talon2006
    Talon2006 New Member Vendor
    I hope the online service has the correct die to bend that and not have it crack... Aluminum that thick can be tricky.
    Also, there is a chance the tapered edges of that will want to ?blow out? when its bent.
    Besides those two points it looks cool!!!
  3. Feb 7, 2025 at 3:00 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    General thoughts:
    The overall design looks OK, but maybe a little small? Looks like it could use another inch (TWSS) along the angled back sides of the sail panels and across the top rail.
    I know that much 1/2" aluminum won't be ultra-light if that's of any concern.
    If I was going to mass produce these I certainly wouldn't be making it all one piece. Bolt together with high quality hardware.
    I see 7 distinct parts: Bed rail bracket (X2), vertical sails (X2), radiused corner joiner (X2), and top rail (X1).
    The rail brackets could be a thinner extrusion in order to better work with tonneau covers.
    The top rail would likely need a stiffening rib along the underside to keep it from bowing.
    Which would likely necessitate raising the top rail higher so that the rib wouldn't block the CHMSL and box light.
  4. Feb 7, 2025 at 3:17 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Looks similar to the Diamondback HD Cab Guard. This one has a mesh to protect the back window.
    I agree that it needs to be taller. I wouldn't want to hit the sharkfin with materials. If I had 2 of your racks (front and back) for carrying long items like my 30' extension ladder or some 12' lumber, etc...
  5. Feb 8, 2025 at 5:23 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Makes it look like an Avalanche……
  6. Feb 8, 2025 at 6:38 AM
    JRS
    JRS New Member
    2012 DCLB
    1/2" is thick for bending. You'll likely end up with surface marring.
    Also, the bed interface is wrong. You have an exterior 90deg and far too tight of a bend radius. The min I'd shoot for would be 4T.
  7. Feb 8, 2025 at 7:41 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Ya or an older Honda Ridgeline. I had this DB Cab Guard on my Ridgeline to make it look like an older version.
