CV axle options?
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, May 11, 2020.
  1. May 11, 2020 at 7:02 AM
    FirstGenVol
    FirstGenVol [OP] Check the name tag. You're in my world now.
    East TN
    2002 AC TRD 4x4 V8
    Since I've got a tear in my cheapo Meineke CV boot I'm just going to replace both at the same time. I think the passenger side is throwing grease too.
    I've heard some recommend NAPA CV's. Others like CVJ. OEM Toyota axles are very expensive.
    I'm leaning towards the CVJ option but I'm open, and looking for other suggestions.
  2. May 11, 2020 at 8:11 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    There’s a thread out here about these somewhere; I’ll see if I can find it.
  3. May 11, 2020 at 3:37 PM
    Professional Hand Model
    Hand Protectors
    From my prior studies, the CVJ is a reman’d OEM Toyota joint. You have the option of siliconized boots in red or black. Also, you have the option for higher angle CV options from CVJ.
    Bad thing is without the OEM core to return you’ll be eating $85 per axle like me when my aftermarkets crap out. Shoulda requested the old cores when my front end was rebuild!
    I’ll probably end up buying new Toyota axles at $430 a pop unless someone thinks the CVJ is better for my situation with the Bilsteins at only one notch up.
    Black Wolf and FrenchToasty like this.
  4. May 11, 2020 at 4:19 PM
    Call these bad boys direct...........Denver, Colorado. Highly regarded by the local folks here. They have a booth at ToyTec Customer Appreciation Day. CVJ Axles 303-297-2448 or 1-800-292-2953. Ask for JP. Jeff Pearson.
    Wynnded likes this.
  5. May 11, 2020 at 4:20 PM
    CVJ not a "joint". Specialize in re-manufactured and beyond. Highly regarded here in CO. Good folks. Know their shit. They sell beefed up goodies too! Depends on need.
  6. May 12, 2020 at 11:14 AM
    Bought my replacements at Advanced auto. About $85 a piece. Ones been on the truck for 90k miles or so with no issues, the other maybe 70k miles or so. Thicker diameter axle shafts and the big boots on the CV's.
  7. May 12, 2020 at 12:25 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Probably a good practice to have a spare set around, maybe even bring them when off roading.
    On my GTI (because my truck is 2wd) I replaced them and kept the old ones. The boots on my old ones split and slung some grease but after cutting the boot off I dont see any dirt introduced and I don't drive that car in rain, so I believe the joint hasn't been damaged. I am going to clean/repack/reboot them. That way the next time a boot tears I can swap immediately before damage is done to the actual joint, then repeat the cycle.
  8. May 12, 2020 at 12:52 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that the joints on the NAPA CVs are cast and are weaker than stock, the Toyota joints are steel and the way you want to go. CVJ's price seems reasonable to me. I used to snap up used functional axles for $100 and modify/rebuild/reboot them in probably a similar way to what CVJ does. I would have no problem paying someone ~$70 each to do the work for me, it was messy. There's also that you're recycling the rebuildable used ones.
  9. May 14, 2020 at 8:24 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I went ahead and ordered 9550 TR's from CVJ. Buy once cry once. Since my truck is lifted a few inches in the front I'd rather go with ones that are not as likely to keep tearing boots.
  10. May 25, 2020 at 1:06 AM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Hey if your doing any offorading or suspension travel when turning (even cornering fast) your boots are probably going to rip agian, what ive seen and done before is put the inner mounting of the boot farther out so the boot is stretched a little so there isnt nearly as much rubbing when turned and the suspension is down.
    Ive also seen youtuve toutorials on it as well so you should look into it!
  11. Nov 17, 2021 at 4:35 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Any new options?
  12. Nov 17, 2021 at 4:43 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Mine are fine but I want a spare for the trail (are they interchangeable?)
  13. Nov 17, 2021 at 5:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    From side to side? Yes.
  14. Nov 17, 2021 at 6:29 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Thank you!
  15. Nov 18, 2021 at 5:08 AM
    lowell66dart
    lowell66dart New Member
    lowell
    South Louisiana
    2001 Tundra 4WD
    Rough Country level, RAS rear springs, Magnaflow, custom front bumper
    Napa has 20% off on 3 items now with free shipping
  16. Nov 19, 2021 at 11:13 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    If it's just a spare, I bought an OEM one from a junkyard on ebay for $60. I've had it for about 6 months with no problems. I figured if it blew right away I'd just have CVJ rebuild it for me.
  17. Nov 28, 2021 at 5:50 AM
    lowell66dart
    lowell
    South Louisiana
    2001 Tundra 4WD
    Here's a pic of the NAPA axle next to a factory Toyota.
    dinosaur likes this.
  18. Nov 28, 2021 at 7:24 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    is that napa the floating type?.? for lifts?
    it looks longer?
  19. Nov 28, 2021 at 8:19 AM
    lowell66dart
    lowell
    South Louisiana
    2001 Tundra 4WD
    These are the ones for lifted trucks. It's not longer I just have it extended in the pic.
  20. Nov 28, 2021 at 8:25 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
