CV Axles for lifted Tundras
Discussion in 'General Tundra Discussion' started by AstroDude, Oct 31, 2022.
  1. Oct 31, 2022 at 4:35 PM
    AstroDude
    AstroDude [OP] New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    I've read over various forms on here about CV angles, but I have questions about upgrading cv axles.
    So my mechanic looked at my CV axles and was worried that they were stretching too much. I've been off-roading with them before and I didn't have any issues.
    A couple of months ago I installed some TRQ CV Axles and I noticed they were a tad bit shorter in length than OEM.
    For TRQ I found 708mm or 27.87 inches in compressed length.
    So I know I can go with the $2299.95 solution for CV axles: https://www.rcvperformance.com/ultimate-ifs-cv-axle-set-for-toyota-tundra-07-sequoia-08-13.html
    Or I can go with these medium to long travel axles for $413.41: https://www.buyautoparts.com/buynow...ve_Axle_Kit/90-91763_2D?xref=26509957&src=pla
    The buyautoparts cv axles are 5.59 longer which I think is significant. Yes, I could spend $2300 on CV axles that I'm sure are rated for 700HP and some other crazy stuff...but I have a 4.6L V8 and I'm just trying to find something that won't break or pop out of the front diff. Has anyone every use those CV axles?
    Stock CV axles have a stock max articulation of 23 degrees and these buyautoparts CV axles have a max articulation of 47 degrees. My concern is quality.
    Current drive terrain mods:
    3.5" Ironman4x4 lift
    1" diff drop
  2. Nov 1, 2022 at 8:17 PM
    AstroDude
    Eddie
    No one?
  3. Nov 1, 2022 at 8:40 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Well, like you said quality. OEM is much better than than anything you can buy on Amazon. You basically have a 2.5” lift, from the diff’s perspective, which means you’re not going to droop down far enough to bind an OEM axle, which means you don’t need 47 degrees of subpar alloy.
    AstroDude[QUOTED][OP] likes this.
  4. Mar 6, 2024 at 7:51 AM
    JaxsonR
    JaxsonR New Member
    Jaxson
    2013 Toyota Tundra 5.7 V8
    3inch ironman 4x4 lift
    I have a 13 5.7 v8 with a 3 inch ironman lift. go to rock auto.com search part number TO8250XTT. it’s a TRAKMOTIV cv axel built for suspension lifts, uses all oem alloys just has bigger boots and a longer shaft for off-road vehicles, and they are only about 115 a piece. been using it for a few years now and they work perfect no tears or over extension.
    airosey and AstroDude[OP] like this.
  5. Aug 5, 2024 at 1:12 PM
    xunil76
    xunil76 New Member
    TX
    2008 Toyota Tundra Crewmax Limited 4x4
    so, given that these have a longer shaft, will these also work on non-lifted trucks? i don't have a lift yet (although i do plan on about a 2.5" - 3.5" lift in the future), but wouldn't mind picking up a couple of these for spares in the meantime in case the stock ones break on me. i didn't see anything indicating how much longer the shafts on these were vs stock.
  6. Aug 6, 2024 at 1:41 PM
    AstroDude
    Eddie
    To fix my issue, I went on ebay, ordered OEM tundra axles, then bought CVJ axle boots for lifted Tundras and bought new outer Cv boots, got new seamless clamps and just rebuilt them. No issues so far which speaks volumes compared to the non-OEM ones I bought.
