CV Boot Noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by stautert, Aug 16, 2021.
  1. Aug 16, 2021 at 6:14 AM
    stautert
    stautert [OP] New Member
    Tanner
    Silver 2015 Tundra Limited CrewMax
    Stock right now
    I have noticed in the mornings or when it rains out and I turn left or right while driving my CV boots make a scrubbing/rubbing noise that’s quite audible. Super aggravating. Anyone ever had that issue? I have a 2015 Limited.
  2. Aug 16, 2021 at 6:33 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    bearing going out?
  3. Aug 16, 2021 at 7:24 AM
    stautert
    Tanner
    Stock right now
    No, it is definitely the CV boot. It’s a rubber type sound. Truck drives smooth. Only does it when wet
  4. Aug 16, 2021 at 7:37 AM
    Netmonkey
    Georgetown, TX
    odd. i don't think that i have ever heard the rubber on the boot itself make noise. there are so many other things on the suspension that can make noise. mount a camera (gopro) pointing at your suspension and see if you can capture the noise.
  5. Aug 16, 2021 at 10:04 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Have you done a visual inspection of the boot? Cracks, cuts, leaks, rips etc...?
  6. Aug 16, 2021 at 10:28 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    If you have a spacer lift you also need the diff drop. Your CV could be slightly extended and rubbing the boot on the inside.
