CV Grease Leak/RTV Fix Attempt
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Mar 27, 2022.
  1. Mar 27, 2022 at 8:23 AM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    I noticed this the other day and snapped some pics. How bad is this leak? Can I keep driving on it fine?
    Leak is on the Pass side.
    If not, what do I have to replace here and how much would that cost?
    Thank you.
    Sorry if the pictures are bad. It's hard to get a good angle under the truck.
    Facing rear of truck.
    Facing pass wheel.
    From underneath.
    Facing front of truck.
  2. Mar 27, 2022 at 9:01 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Take a look at the hoses on the reservoir. Could just be a loose clamp.
    Jack McCarthy and DarkMint[OP] like this.
  3. Mar 27, 2022 at 11:46 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Dip a finger in it. That almost looks like axle grease flung around.
  4. Mar 27, 2022 at 5:23 PM
    This. Notice the spatter. Also, is that your O2 sensor harness hanging free in the 2nd pic?
    DarkMint[OP] likes this.
  5. Mar 27, 2022 at 5:39 PM
    DarkMint
    Ben
    Yes, I discovered this spatter while replacing my B2S1 o2 sensor. I'll get under the truck and take a closer look when I get the chance. Driving the Honda for now.
    If it's axle grease being flung around, what would cause this? And how much would it cost to fix it?
    ... And most importantly is it safe to drive on?
  6. Mar 27, 2022 at 5:41 PM
    Damn just noticed my pic didn't post. Check this out. Clear splatter lines below, to the side, and above.
  7. Mar 27, 2022 at 5:43 PM
    DarkMint
    Ben
    Wow.. Thank you. What am I looking at?
    Darkness likes this.
  8. Mar 27, 2022 at 5:53 PM
    artsr2002
    'Yonder
    M'yes upon further review that is grease from your CV. M'yes.
  9. Mar 27, 2022 at 5:57 PM
    See all that splatter that looks like a someone sprayed black popcorn everywhere, or radiating lines of weld spatter? That's heavy oil or grease sling.
    You can see it on the bronze piece in the background (top right arrow) which is above this. Also on the left side, just not as obvious. But it's clearly peppering the two frame crossmembers in the lane I drew with the red lines.
    DarkMint[QUOTED][OP] likes this.
  10. Mar 27, 2022 at 6:02 PM
    DarkMint
    Ben
    Got it. Looks terrible... I like the lines you drew btw, very clear. What part am I looking at replacing? Is it safe to drive on or am I f*cked?
  11. Mar 27, 2022 at 6:15 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes it's safe and very common. You can either reboot the CV axle or replace it. No need to stress over it.
  12. Mar 27, 2022 at 6:26 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My truck had axles that looked similar to yours when I bought it. I rolled with them for a while. You can either replace the whole axle or do a reboot which to me seems like a big pain. You want really good axles go with CVJ remanufactured. You want the best axles get OEM (real high dollar). I got the extra beefy rock auto axles (which are exactly the same as NAPA HD axles) and they seem to be pretty good quality and dont break the bank.
    Hang on to that factory axle as if you ever decide to go CVJ remanufactured then you'll need an OEM axle for the core charge.
  13. Apr 12, 2022 at 4:21 PM
    DarkMint
    Ben
    Thanks for all the info.
    I'm going to drive the truck with the axle like this on a 2-week, 2600 mile round trip in a couple weeks. Is that fine or is it suicide? For the record I'm not sure how long it's been leaking like that, and have driven the truck on many longer-distance trips already.
    Also, can you point me toward a good re-booting tutorial or axle replacement tutorial? I'm weighing my options, not worried about spending the money if it'll contribute to the truck's longevity.
    Found a couple videos on Youtube actually. Will reference.
  14. Apr 12, 2022 at 5:54 PM
    DarkMint
    Ben
    Upon watching some videos, it looks like either I'm missing a clamp there or it's buried in grease and hence invisible. The boot itself doesn't look torn, hopefully I can just re-clamp it. Will need to clean it up.
  15. Apr 12, 2022 at 7:16 PM
    NickB_01TRD
    Nick
    KY
    I think I can see the clamp on yours still. Mine were about the same. Seems like it's ripped under the clamp or something. If money is no object I'd say get brand new OEM. Otherwise do CVJ reman. They send you axles they have rebuilt and then you ship them your OEM axles for them to rebuild for someone else. That's the route I would have went but just didn't feel like spending the money on them.
  16. Apr 13, 2022 at 2:58 PM
    DarkMint
    Ben
    I'm thinking CVJ reman or re-boot it myself after my big trip. For now I need the truck so I'm just gonna drive on it. Thanks for the recommendations, I definitely feel like I know how to proceed with this issue now.
  17. Apr 14, 2022 at 8:02 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Mines looked like that for 20,000 miles, haven't cared to replace them yet. No need to worry..
  18. Apr 16, 2022 at 6:26 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
  19. Apr 16, 2022 at 3:51 PM
    DarkMint
    Ben
    What brand is that? I've heard about the "red cv boot" just dunno where to get it.
    Your self description says OEM junkie but these don't look OEM. :D
  20. Apr 16, 2022 at 4:39 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I’d CTL ALT DEL that mofo. If grease is getting out, then moisture and dirt can get in. Grease is there to lubricate the axle. Why take the chance of having to repair/replace the axle while on the road?
    FrenchToasty likes this.
  21. Apr 16, 2022 at 6:02 PM
    abcinv
    Tommy
    South of ATL
  22. Apr 16, 2022 at 8:12 PM
    DarkMint
    Ben
    abcinv[QUOTED] likes this.
  23. Apr 16, 2022 at 8:55 PM
    abcinv
    Tommy
    South of ATL
    Guilty, I am a fan of these boots. They do exactly what they’re designed to do. Just as my Husky liners do, all can’t be OEM on 16 year old trucks.
    And guilty again, that was my truck :thumbsup:
  24. May 1, 2022 at 8:25 PM
    DarkMint
    Ben
    I cleaned the joint off very well with a brake cleaner-soaked shop towel and for the life of me could not identify any visible leaks. The boot itself looks fine. So my best guess is it's coming from the clamp area, and the splatter seems to agree with my guess.
    I am considering doing a reboot with a really good aftermarket kit but have to rustle up the cash and the time. Until then I have smeared some RTV from finger to the non-articulating clamped area that it SEEMS to be leaking from. After it sits for the appropriate 24hr curing time I'm going to wrap it with clear Flex Seal tape.
    Before you say "this man should never work on a vehicle again" I'm doing this in the name of let's see what happens. The joint is not clicking even though it's lost some flung grease. It's a temporary quick fix until I can fully reboot.
    Cleaned up. The angle is the way it is because the truck's on jack stands:
    RTV applied using finger and turning the wheel with my other hand to coat it all around:
    My weapon of sin leftover from recent trans pan replacement:
    abcinv, bmf4069 and Filthyphil like this.
  25. May 1, 2022 at 11:18 PM
    NickB_01TRD
    Nick
    KY
    One of mine looked like someone had caulked it with household caulking when I got it. Was still leaking though. Hopefully you have better luck.
  26. May 2, 2022 at 3:15 PM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    I got a set of these "second hand" still new from @TRDGen (maybe his account got deleted?) for like $20 or something. I guess I got a steal on them. they feel very high quality. not installed yet.
    bmf4069, DarkMint[OP] and Mogo Gogo like this.
  27. May 2, 2022 at 4:42 PM
    abcinv
    Tommy
    South of ATL
    Hoping this buys you some time!
  28. May 2, 2022 at 8:11 PM
    DarkMint
    Ben
    Admittedly shoddy tape job around the RTV'd area, about 3 or 4 layers of clear Flex Seal tape wrapped around. It was hard to tape neatly considering there are a few different circumferences in that small 1" wide area to wrap around. But the Permatex Ultra Black is the main leak stopper, the tape is just there for my peace-of-mind that I can't find the words to explain. :thumbsup:
    I will be reporting back here if it holds up or if it fails, or if I've completely missed the leaking area and wasted effort.
    Filthyphil, bmf4069 and Sirfive like this.
  29. May 2, 2022 at 9:03 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I would definitely unclamp it if it can't be tightened, check if adequate grease left and reclamp with a $30 tool you now need to go buy! :laughing:
    Either that or zip ties and I wouldn't do zip ties for something critical like a CV boot.
  30. May 2, 2022 at 10:27 PM
    DarkMint
    Ben
    No way would I go the ziptie route! The RTV and Flex tape is the limit of how far I'd go haha. I don't need a special tool to remove that clamp do I?
    My plan ultimately will be buy snap ring pliers, new boot and grease, 35mm socket, and new clamps with soft padding on the inside so the clamp doesn't cut into the clamped boot portion. It's a matter of ponying up for good stuff and making the time.
