D solenoid locate
Discussion in '1st Gen Tundras (2000-2006)' started by aprendiz1, Sep 6, 2024.
  1. Sep 6, 2024 at 12:53 PM
    aprendiz1
    aprendiz1 [OP] New Member
    jaime
    2005 tundra where is located the solenoid D
  2. Sep 6, 2024 at 1:38 PM
    Inside the transmission. Search feature will lead you to a ton of information about it, how to fix errors.
  3. Sep 6, 2024 at 3:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    The solenoids are connected to the valve body and have an electrical harness within the transmission pan. They can be fairly easily replaced if you drop the pan. Be careful as the pan bolts go through the transmission flange and are prone to corrosion and breaking when removed.
  4. Sep 6, 2024 at 5:51 PM
    And stripping during reinstall.
  5. Sep 8, 2024 at 6:59 AM
    aprendiz1
    jaime
    Thanks for your help guys but I need know what's D.if is S1,or,SL1, etc.
  6. Sep 8, 2024 at 9:43 AM
    bfunke
    South Carolina
  7. Sep 8, 2024 at 9:46 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Make sure that your issue is the solenoid itself and not the wiring going to the solenoid. I've had issues with the wiring that goes to the solenoid shorting out. Simply replacing the solenoid just made it fry the new solenoid.
    shifty` likes this.
  8. Sep 8, 2024 at 3:32 PM
    aprendiz1
    jaime
    ok, I understand now. I will try to check the Electric cord first, I appreciate your help.
  9. Sep 8, 2024 at 4:11 PM
    FiatRunner
    Jack
    Do you have a check engine light code? That can often tell you if it's a circuit issue.
