Dash Clock resets to 1:00 whenever turned off and on.
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraKTM, May 31, 2018.
  1. May 31, 2018 at 2:19 PM
    TundraKTM
    TundraKTM [OP] New Member
    2007 Tundra Limited 4x4
    Just bought couple weeks ago. Dash clock resets to 1:00 even though you set it. Once you start truck up it's 1:00. Ground Hog clock I guess. Any ideas on what the issue is? Thanks.
    NewImprovedRon likes this.
  2. May 31, 2018 at 2:25 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    A couple things check your fuses for the dome lights and IOD under the dash and under the hood.
    Next if those are fine would be to get your battery tested, if the voltage drops low enough during cranking it'll reset the clock.
    NewImprovedRon and mudslinger79 like this.
  3. Jul 31, 2018 at 7:49 AM
    TundraKTM
    Sorry for taking so long to get back. You were right. The fuse was burnt for Dome lights. Works fine now. Thanks.
