Dash lights - Replacement and LED - Dimming
Discussion in '1st Gen Tundras (2000-2006)' started by 2005ToyotaTundra, Dec 30, 2019.
  1. Dec 30, 2019 at 9:20 AM
    2005ToyotaTundra
    2005ToyotaTundra [OP] New Member
    Anyone know where to order the green caps for the bulbs
    Or what an acceptable replacement item would be?
    Thanks in advance
    PS
    If I go with LED Bulbs, does the dimming function still work correctly?
    Any other info is also appreciated.
  2. Dec 30, 2019 at 11:33 AM
    truckee_mctruckface
    truckee_mctruckface New Member
    Charles
    Seattle
    2005 DC SR5 TRD off road Spectra Blue
    My dimming works with the LED lights.
  3. Dec 30, 2019 at 12:38 PM
    TT2002
    TT2002 New Member
    J
    LED is the way to go
  4. Dec 30, 2019 at 4:29 PM
    Professional Hand Model
    Hand Protectors
    Dimming works with LED. Just buy colored LED bulbs instead of the rubbers.
  5. Dec 30, 2019 at 7:56 PM
    2005ToyotaTundra
    Any brand(s) preferred? Where do I get these LED?
  6. Dec 30, 2019 at 8:06 PM
    Seina_Yamada
    Seina_Yamada New Member
    2003 Toyoda Tundra SR5
    I converted my 2003 dash-lights to leds i got off eBay. Dimmer works great, but I went with blue lights. Be warned if you go led the lights are mono-polar meaning they only light up plugged in one way, so test everything Before reinstalling your cluster.
  7. Dec 30, 2019 at 8:52 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
  8. Dec 30, 2019 at 10:11 PM
    Aerindel
    Aerindel New Member
    Montana
    Dimming works....ish. Full dim is about equivalent to full bright with the old lights. I found that I needed to stick with incandescents for the 4WD light as that is on all winter and was way too bright with white LED's. (those lights are non dimming regularly so of course do not dim as LEDs either)
    FYI, do not replace the battery warning light with an LED. It must be an incandescent for your charging system to work.
  9. Dec 31, 2019 at 6:00 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You also want to keep the fuel light incandescent if you want that to function also.
    TX-TRD1stGEN and BubbaW like this.
