diamondback tonneau cover Led Lights
Discussion in 'Tonneau Covers, Caps and Shells' started by tundratexas89, May 12, 2024.
  1. May 12, 2024 at 8:15 PM
    tundratexas89
    tundratexas89 [OP] New Member
    Has anyone installed led lights underneath the cover on a 2020 Tundra crewmax?
  2. May 13, 2024 at 2:47 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    You have lots of options depending on if you want them mounted to the bed or to the cover.
    These are hard wired and have a switch, and seams to be a popular option for mounting to the bed.
    You can search Tundras.com for more first hand info on these.
    https://mattgeckoleds.com/shop/ols/...th-bed-mounted-switch-toyota-tacoma-2005-2021
    These are options if you want to mount to the cover. Wireless and easy to install, but you may need 2 depending on what your goal is.
    https://diamondbackcovers.com/products/diamondback-light
    https://www.amazon.com/dp/B00FPOSNZK/?coliid=I2CGOZ1B8W3A23&colid=8IUHABEWWKXQ
    I personally use 2 of these since I do not typically get in the bed at night, but have them just in case.
    They are rechargeable and I can use them for other uses when not needed in the truck. They are inexpensive as well.
  3. May 13, 2024 at 6:51 AM
    tundratexas89
  4. May 13, 2024 at 7:55 AM
    Bergy24
    Bergy24 New Member
  5. May 13, 2024 at 8:22 AM
    SD Surfer
    Bruce
    So Cal
    Those are the ones I used and I'm very happy with them. SO nice to be able to just hit the switch and see what I'm doing without futzing with flashlights.
    Fortunately for me I had already run power into the bed for a 12V/USB receptacle so I just tapped into that. It's direct to the battery and constant hot. I wanted to be able to plug in or turn on whatever without needing to turn on running lights or anything.
    I think anything existing you'd tap into would need to be energized by another switch in the cab.
    Some people in the reviews complain about the adhesive on the Nilight LED strips but I've had no problems, just clean the mounting surface REALLY WELL with alcohol.
    I mounted mine under the tonneau rail/flange. That 3-piece kit is a pretty good fit, a little extra wire between pieces but I just zip tied and tucked it up in the corners and you can't even see it.
    The switch is mounted under the bed rail just behind the 12V receptacle.
    bulldog93 and Bergy24 like this.
  6. May 13, 2024 at 4:59 PM
    tundratexas89
    Thanks for the help and tips guys. Appreciate it.
  7. May 13, 2024 at 6:27 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
  8. May 13, 2024 at 7:40 PM
    Willard
    Willard New Member
    2024 F250
    Mattgecko kit on my old tundra was easy and worked great under my diamondback:
  9. May 13, 2024 at 7:48 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
