Diff and transfer case fluid change
Discussion in '2.5 Gen Tundras (2014-2021)' started by mech_engineer09, May 14, 2021.
  1. May 14, 2021 at 10:35 AM
    mech_engineer09
    mech_engineer09 [OP] Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Hey everyone,
    just went to the dealership to pick up the hardware to change the front and rear diff and transfer case fluid. Parts dude told me I only need what’s shown in pictures. Can do the front and rear diffs with that and transfer case doesn’t use any washers. Is this true or do I need to get something for the transfer case. Just don’t wanna get down there and drain transfer case fluid only to find out I need a new crush washer or something. Thanks. Don’t want any. Just reuse the washers comments. Not doing that. They’re cheap. I’m not worried about saving a couple dollars doing this. Thanks
  2. May 14, 2021 at 10:45 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Can't help much but I'm related to one of the higher level technicians there. That's a good dealership.
    I would've thought the transfer case would use a washer but I can confirm that.
    mech_engineer09[OP] likes this.
  3. May 14, 2021 at 10:49 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Doesn't look like it needs gaskets with this style plug.
    https://www.tundras.com/threads/3rd-gen-2014-diy-transfer-case-oil-change.53452/
    The kits I had bought in the past were for "toyota" not Tundra specific. I wonder if I just didn't use the transfer case part number.
  4. May 14, 2021 at 10:55 AM
    15whtrd
    15whtrd Mr. Blonde
    The transfer case was tapered pipe plugs on the 14 and up. Just a little Teflon paste or even Teflon tape should be sufficient. Doesn’t need to be stupid tight either.
    Jaypown likes this.
  5. May 14, 2021 at 11:04 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Those crush washers do nothing to create a seel. They are just to help prevent over torquing of the bolts, once its crushed it doesn't provide anything more than just a typical flat washer. Even the washer in the engine oil drain is just a blue flat washer, replacing it doesn't provide any added benefit as long as you are torquing the bolt correctly.
