Diff Mounts
Discussion in 'Suspension' started by ZSShak, Aug 6, 2021.
  1. Aug 6, 2021 at 8:52 AM
    ZSShak
    ZSShak [OP] New Member
    2017 Tundra 4X4 Going from a 6 Inch RCX lift kit to a 4.5 BDS Coil Over Kit. Need Factory OEM Diff mounts for the BDS kit. Anyone do a lift kit recently that has OEM mounts and hardware. I'm happy to buy them from you.
    Thanks!
  2. Aug 6, 2021 at 11:09 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Sounds like you're asking for the crossmembers that are cut out (and usually thrown away) in order to make room for the drop brackets on 6"+ lift kits. If you found one it would need to be welded back on - might have to remove the engine (not sure) in order to weld the top part of the crossmember. The other problem is that the crossmember you do find may not be the right length you need (too short) and you would need to add more metal to it, which if you do, then might as well just go with a custom crossmember.
    Edit: Once your diff is at the stock level, regardless of the type of crossmember used, you can then swap out the knuckles to go back to stock form and proceed with the new lift kit installation.
  3. Aug 6, 2021 at 11:19 AM
    ZSShak
    No don't need cross members...need differential mounts for the factory differential. RCX uses their own diff mounts. BDS 4.5 kit uses factory diff mounts.
  4. Aug 6, 2021 at 11:53 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Oh I see, you're looking for these guys right? I think I have some. Where you located?
    Ely010606 likes this.
  5. Aug 6, 2021 at 12:11 PM
    ZSShak
    Yes!!!! itsthe 2 that you pointed out and one on the drivers side rear of the diff. 3 Diff mounts total. I'm In Houston. Where are you?
  6. Aug 6, 2021 at 12:14 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Cali. Let me double check first that I have them - there yours for free.
  7. Aug 6, 2021 at 3:56 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    So I have the bottom two mounts. I don't have the bolt that mounts to the crossmember though. If you have a friend with a Tundra you could remove the crossmember bolt, one at a time, to measure it and then order replacements online - don't have to buy through Toyota. If you still want these PM me your address and I'll ship it to you - free - doesn't cost me anything to ship.
  8. Aug 7, 2021 at 8:33 AM
    ZSShak
    Dude that would be awesome!
  9. Aug 7, 2021 at 8:34 AM
    ZSShak
    23901 Eastex Freeway Kingwood Tx 7739
  10. Jan 10, 2022 at 3:42 PM
    Drew1
    Drew1 New Member
    2007 Tundra 5.7 4wd
    I need the same bolts since I'm removing the leveling kit and Front Diff drop rubber bushings & bolts from my 2007 DC. Anybody else happen to have the two vertical bolts, or know their part number so I can order them online? It would save me from going to the dealer.
    Fotnot likes this.
  11. Jan 18, 2022 at 11:44 AM
    Cruzer
    Cruz
    Sunnyvale, CA
  12. Jan 18, 2022 at 12:06 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    i tagged you in another post.
  13. Aug 26, 2022 at 6:44 PM
    TMK112
    TMK112 New Member
    TK
    2014 crew max sr5
    I’m going through the same issue. Removing a pro comp kit that got rid of all that too. anyone know part numbers for
  14. Aug 27, 2022 at 6:03 AM
    Cruzer
    Cruz
    Sunnyvale, CA
