Difference between JL 12TW3-D4 and the JL 12TW3-D8?
Discussion in 'Audio & Video' started by jobe, Aug 16, 2020.
  1. Aug 16, 2020 at 12:44 AM
    jobe
    jobe [OP] New Member
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    does anyone know the difference between the JL 12TW3-D4 and the JL 12TW3-D8. they are subwoofers and one is 8 ohms and the other is 4? I have no idea what that means though. i will have a jl jd 1000/1 monoblock class d amp with a dmh w8600nex head unit if that makes a difference to the subs.
  2. Aug 16, 2020 at 4:11 AM
    Gould71
    Gould71 Member
    2017 Platinum Midnight Black
    TRD swaybar, TRD shift knob, FN FX Pro wheels, Toyo AT/IIIs, VLED interior and puddles
    Most modern amplifiers like to see a load of 4 Ohms or less. The D8 sub would work best paired with another one wired in parallel to give 4 ohms.
    You could use a single D8 with your amp but it would not let it put out full power.
    nobodyintexas likes this.
  3. Aug 16, 2020 at 4:26 AM
    Gould71
    Gould71 Member
    Just looked up your amp- its 1000 watt rated power is at 2 ohms. If you hooked up two D4s in parallel you’d get the full rated power out of your amp.
    Edit- just realized those subs have dual voice coils. You could wire the D4 voice coils in parallel for the 2 ohm load.
    619Tundra and jobe[OP] like this.
  4. Aug 16, 2020 at 9:39 AM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    I got the d4s!!!
    GNTundra likes this.
  5. Aug 16, 2020 at 9:46 AM
    Gould71
    Gould71 Member
    2 each? Then you you’d want to make sure the voice coils in each one are in series, then wire the two subs in parallel for 2 ohms. Less than two ohms could smoke the amps. Good luck- JL is good stuff.
    Damn- not enough coffee yet this morning. With two wired D4s together you may not get the two ohms. Series the voice coils and parallel the two will get you 4 ohms. Parallel the voice coils and series the subs will get you 4 ohms as well. Parallel everything and you’ll get 1 ohm. Too low for the amp.
  6. Aug 16, 2020 at 9:47 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    D4= dual 4 ohm
    D8= dual 8 ohm
    They allow for different wiring configurations. Depends on how many subs you will be using and what your amp is a capable of.
  7. Aug 16, 2020 at 9:49 AM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    i have the jl jd1000/1 class d mono amp with 2 12tw3 d4s. sealed box
  8. Oct 5, 2022 at 12:41 PM
    METALMACHINE71
    METALMACHINE71 New Member
    Hey y'all. I am planning on running 3 of these 10TW3's in my 2012 Tundra. I will be using this amp. What should I be using, D4's or D8's?
    619Tundra likes this.
  9. Nov 7, 2022 at 11:24 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Use the D4s. I have a pair of BNIB JL 10TW3D4s for sale of you're interested.
