Different version of skid plate bolt issues
Discussion in '1st Gen Tundras (2000-2006)' started by DBombs, Jan 16, 2025.
  1. Jan 16, 2025 at 7:09 PM
    DBombs
    DBombs [OP] I Like Old Trucks
    NE Atlanta
    2006 Tundra DC SR5 V8 4x4 TRD
    My problem was a variation of the skid plate bolt issues. Super simple stuff, but I’ll share what I did.
    Both rear bolts had been replaced with pass thru bolts and a nut. The problem with the pass thru bolt is there is not a good way to get a wrench on the nut. The bolt just spins. Or maybe I’m just slow. I have no idea how someone managed to get them on in the first place.
    Pass thru bolts with nut used at both rear skid plate bolts.
    No real way to get a wrench on the nut that I could see. Very limited access to the nut.
    Tried all versions of pliers, tried long levers to try and get leverage on the nut and get some kind of resistance to hold it in place.
    The driver’s side turned out to be easy. A long flat screw driver used as a lever allowed me to get pressure on the skid plate. One hand prying on the screw driver to create preasure, the other hand turning the ratchet. The tension was enough to hold the nut while the bolt turned and backed out.
    The same method would not work on the passenger side. I tried all kinds of lengths and angles of pliers and levers. Couldn’t get anything to reach the nut or get enough of a grab. Couldn’t get great pics for this side, but ended up using a magnetic wand to feed a deep socket onto the nut. Had to use a 14 mm socket even though it turned out the nut was 13 mm. Could not get the 13 to slip onto the nut. Dexterity and access was very limited to get to the nut in any functional way.
    Once the socket was on the nut, I used 16 inch long needle nose pliers through the top access hole and thankfully they got enough grip on the socket for the bolt to back out. There was no way to get any kind of proper application of a wrench/plier on the nut, or a ratchet on the socket.
    Maybe there is a more specialized tool than I have. I tried flex extensions and knuckles, but none had the correct combination of length or angle. In hindsight, maybe a small enough cutting wheel on a rotary tool would have got to the bolt.
    Can’t imagine there are many skid plates attached this way. It seems like an equal challenge to get the nut on in the first place.
    At some point I’ll tap the hole to get threads. The receiving nuts are still welded on inside the frame, but someone drilled out the threads to allow for the pass thru bolt. I’ll get to it eventually, for now I’ll leave the skid plate off. I’ve gone plenty of stretches in the past with no skid plate
    Jack McCarthy and shifty` like this.
  2. Jan 16, 2025 at 8:05 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    You could always weld a new nut on top of the drilled out one, if you or a friend have a welder. Use the pass through bolt to hold it together and align the holes.
    JasonC. likes this.
  3. Jan 17, 2025 at 12:38 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    Ugh, this was my nightmare for months after breaking two of the bolts inside the weldnuts attached to the skidplate. Mine also remained off for months until I had time to finally drill mine out and retap the threads. I also recommend either cutting new, larger threads on those weldnuts or welding on new nuts on top of the old ones with the correct thread size to match the original bolts (or whatever your pass-through bolts are). //Shudder//
    The front three all bolt-and-nut onto my new bumper! Easy peasy.
  4. Jan 17, 2025 at 4:04 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    The hitch on my 4R had a couple nuts with metal ribbons attached that were about 4 inches long so you could hold the nut in position while you tightened the bolts. Might try a trailer hitch shop to see if they have anything you could use.
    G_unit3000 likes this.
  5. Jan 17, 2025 at 3:17 PM
    DBombs
    NE Atlanta
    Good suggestions, thx. @assassin10000 @JasonC. Regarding welding a new nut, it seems like access would again be a challenge? The only access is where the LCA attaches. I guess there is one smaller hole in the frame from above as well.
    I’ll get to it later than sooner. It’s not at the top of the list yet. Might could also get it clean enough on top of the weldnut to use epoxy to attach a new nut instead of welding.
  6. Jan 17, 2025 at 5:15 PM
    shifty` No Water in the Water Fountain
    You may want to look into whether someone makes a rivnut that large. I know they make a 1/2” rivnut, I’ve had to use one before. Wondering if that’s not the best option here.
    whodatschrome likes this.
  7. Jan 17, 2025 at 5:22 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I use U-nuts and a metal tab with a hole drilled in it. The metal tab sits inside the U-nut. The metal tab needs to be long enough where it catches on the frame, just have to stick your hand up in there to steady it while you first thread the bolt in. You could also weld a nut on said tab instead of using the U-nut, but same idea otherwise. Has worked pretty well for me over the last few years.
    https://www.amazon.com/gp/product/B0040D2OGQ?ie=UTF8
    • [​IMG]
    Jack McCarthy likes this.
  8. Jan 17, 2025 at 5:34 PM
    We used these and capture nuts quite frequently in technology installs and trade show setups.
    des2mtn[QUOTED] likes this.
  9. Jan 17, 2025 at 5:53 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I wouldn’t go crazy and just remove the nut and put an extra long bolt in the frame pointing threads down towards the skid plate and use a loctited nut to hold it in place.
    Then when going to put on the skid plate, use another nut instead. Easy peasy.
  10. Jan 17, 2025 at 6:58 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Depends on how the clearance is. You'd do it with the skidplate off so there would be room.
    It only needs one or two solid tacks to hold it anyways.
  11. Jan 17, 2025 at 7:04 PM
    DBombs
    NE Atlanta
    Nice. Thx. I haven’t used Rivnuts before. Fun learning new tools/techniques/etc. I’ll see which one seems most practical, including tapping new threads
