Differential additive - why?
Discussion in '2.5 Gen Tundras (2014-2021)' started by swallace, Jul 21, 2021.
  1. Jul 21, 2021 at 11:45 PM
    swallace
    swallace [OP] Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    I recently was able to get my hands on the maintenance history of my truck (I purchased it with 85k miles). At 77k miles, a Toyota dealer added differential additive and I’m trying to understand why. Is the only reason to use additive to reduce chatter if it shows up? My local dealer said they don’t recommend changing the differential fluid ever, yet this other dealer used additive…which seems like conflicting messages. It’s not really lifetime if additive needs to be put in there. Wouldn’t it be better to do a complete flush?
  2. Jul 22, 2021 at 12:43 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Dealers are crooks, they will sell a fridge to an eskimo, if the Eskimo don’t know better.
  3. Jul 22, 2021 at 12:51 AM
    AZBoatHauler
    So.Arizona
    Agree with ^ but the notion you should never change the diff oil is also completely illogical considering cost to service versus cost to repair/replace. I’m sure you could go a good long while on the stock fill but there comes a point where you should clean / check the magnet and make sure you don’t have any water intrusion - not to mention freshen the oil.
    If you can lay on the ground and loosen/torque a bolt you are capable of draining and filling the diff. Get some new washers from your local dealer parts counter for the drain and fill bolts and 4 qts of your favorite 75-90 gear oil spend 10 minutes watching YouTube and you’re all set. When you see how gross the oil draining is you’ll be glad you aren’t keeping it in there “forever”.
    2mchfun and WILLINH like this.
  4. Jul 22, 2021 at 1:00 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    It’s 30-50k service, 50k if I use synthetic
    HulkSmurf14 likes this.
  5. Jul 22, 2021 at 1:07 AM
    I’m wondering why the dealership would put additive in at all anyway. What additive did they put in?
  6. Jul 22, 2021 at 3:22 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    You need a new dealer !
  7. Jul 22, 2021 at 4:05 AM
    timsp8
    NY
    Maybe the previous owner put in an lsd. My dealer put in additive for me because I had an lsd.
  8. Jul 22, 2021 at 5:13 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    When I had it done at the dealer my receipt said "blinker fluid." But it didn't specify a manufacturer or weight. Makes me sooooo mad. I don't even know if they actually did the work. Why would they use blinker fluid when I requested a differential oil change???
    Life is hard.
    hagrid likes this.
  9. Jul 22, 2021 at 5:54 AM
    2mchfun
    Take fill plug out before you take out drain plug, always want to be sure you can fill before you drain anything.
  10. Jul 22, 2021 at 3:59 PM
    swallace
    Steven
    Tri-Cities, WA
    All it says is "LTD Slip Additive". I don't know what they put in.
    The truck was basically stock when I got it. Considering it was a 4.6 and stock, I would be surprised if it had an LSD installed. How would I know if an after-market LSD was installed?
  11. Jul 22, 2021 at 4:02 PM
    NWPirate
    Zach
    WA
    It would be clearly labeled on the diff.
    AZBoatHauler likes this.
  12. Jul 22, 2021 at 5:56 PM
    timsp8
    NY
    I think you can still check this way.
    Raise the rear axle to put both rears tires off the ground. Spin one. If they spin the same way, you have an lsd. If they spin opposite directions, open diff.
  13. Jul 22, 2021 at 5:57 PM
    Most differential lube has LS additive in it and it won't hurt anything except your wallet since the Tundra has not had a LS option since 2007.
    You can find out pretty quick if an aftermarket LS was installed. TC off, dirt road, from standstill mat the fuel pedal.
  14. Jul 22, 2021 at 7:04 PM
    swallace
    Steven
    Tri-Cities, WA
    Thank you all. Very helpful!
