disable alarm on 2016 Tundra Platinum
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tuffy, Jun 17, 2021.
  1. Jun 17, 2021 at 7:39 PM
    Tuffy
    Tuffy [OP] New Member
    Gabriola, BC
    2016 Tundra 1794 Platinum
    none
    Hello, Does anyone know how to disable the alarm on a 2016 Tundra Platinum. Our dog will bark for a few minutes and set the alarm off. I have removed the fuse for the horn but there must also be a second horn for the alarm only as it sounds off but with a different tone. Even leaving
  2. Jun 17, 2021 at 9:14 PM
    TundroLoco
    TundroLoco New Member
    Angel
    2018 tundra SR5
    why no just turn down the GBS sensor a little.
  3. Jun 18, 2021 at 7:17 AM
    Tuffy
    Gabriola, BC
    none
    Thank you for your reply. Was not aware of a GBS sensor but now know what it is. I will have to locate it and see how it is adjusted. Any tips on how to adjust
  4. Jun 18, 2021 at 8:16 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  5. Jun 18, 2021 at 8:21 AM
    frichco228
    these may be helpful too
    https://itstillruns.com/disable-tundra-factory-alarms-7771263.html
    https://www.tundras.com/threads/factory-alarm-keeps-going-off-every-20-min.32755/#post-812393
    https://www.tundras.com/threads/help-alarm-still-going-off-updated.73983/
    How do you turn off the alarm on a Toyota Tundra?
    Keyless Remote
    1. Insert the key into the ignition. Turn the key to the "ON" position. ...
    2. Press the "Lock" button on the driver door panel. Press the "Unlock" button on the driver door panel. ...
    3. Press and hold the "Panic" button on the vehicle remote control for two seconds to disable the alarm.
