Disable/remove headlight leveling adjuster
Discussion in '2nd Gen Tundras (2007-2013)' started by tktundra, Mar 20, 2021.
  1. Mar 20, 2021 at 2:12 AM
    tktundra
    tktundra [OP] New Member
    2010 Tundra SR5 5.7V8
    I recently bought replacement headlight assemblies for my 2010 SR5 Tundra. After removing the old ones I realized the new ones I purchased do not support the headlight level adjuster motor. I honestly didn’t even know I had the adjusting switch in the cab until now so I don’t mind not being able to use the motor with the new lights.
    The question I have is if I should just return the ones I bought and purchase the correct assembly with leveling adjusters or can I cap off or disable the adjuster and use the assembly I already bought?
    Thanks for any help.
  2. Mar 20, 2021 at 2:46 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    I would return and get model correct lights. It’s a nice feature.
    You could just not plug in the motor actuator wire.
    Black Wolf likes this.
  3. Mar 20, 2021 at 4:12 AM
    Return them of course. I agree that the leveling is a nice feature to have. You can adjust on the fly depending on your load.
  4. Mar 20, 2021 at 5:27 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    I upgraded to sequoia headlights and lost the leveling feature that I literally never used. Just leave the wire unplugged and the switch where it is, won’t hurt anything.
  5. Mar 20, 2021 at 6:02 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Get the correct one, if you ever carry a load in the bed at night you'll be glad you did... along with all the other drivers.
    Danny3737 and Black Wolf like this.
  6. Mar 20, 2021 at 6:27 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Get the correct one. I love The fact I can adjust them on the fly, especially when it gets foggy
