Disable WIFI / Cellular / Bluetooth?
Discussion in '3rd Gen Tundras (2022+)' started by TowTruck, May 10, 2024.
  1. May 10, 2024 at 10:12 AM
    TowTruck
    TowTruck [OP] New Member
    Hey guys I am looking at a 2023 / 2024 model year Tundra. I am curious if there is a way to turn off the WIFI and cellular? Either through the menu system etc. or more aggressively by pulling a fuse or power input if there’s no option to turn it off? Would the Bluetooth be able to be controlled by the driver and turned off / on as needed? Thanks for any insight!
    ChucklesToy likes this.
  2. May 10, 2024 at 10:53 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Yes, WiFi, Cellular and Bluetooth are all controlled separately in settings.
  3. May 10, 2024 at 3:59 PM
    TowTruck
    Thanks, I did not realize there were settings in the menu to turn all 3 options off. I saw a topic regarding Tacomas where people were going to pretty in depth lengths to disable these features, I guess / sounds like the Tundra has additional options to actually turn this off if desired. If so that would be convenient.
  4. May 10, 2024 at 4:18 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    I run with my iPhone connected via Bluetooth and use CarPlay while the WiFi and Truck's cellular are turned off. Of course, my iPhone's cellular remains on. I can separately turn the truck into a hot spot or let other passengers use Wifi or just leave it off. It is all controlled in the Multi-media platform.
    Jackstraw likes this.
  5. May 10, 2024 at 7:37 PM
    TowTruck
    Thanks. Do you know if this setting totally turns off any cellular connection to and from the truck? I thought I had read that there was some feature that was always trying to connect to relay data to and from the cloud or what have you.
  6. May 10, 2024 at 9:12 PM
    Hella Krusty
    Hella Krusty New Member
    You control it. ALL of it . Nothing is on unless you want it on
  7. May 11, 2024 at 7:01 AM
    kirkb
    kirkb Offending Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Not trying to disagree but I just went through the settings and unless I missed it, I can't find anything related to cellular. I did find wifi, hotspot, and Bluetooth. But no cellular control.
    Hoping I'm wrong
  8. May 11, 2024 at 10:03 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Hotspot is cellular and if you don’t sign up for mobile cellular from AT&T, you won’t have cellular.
    The other area of “connectivity” that you control is Connected Services through the Toyota app. You control these by not accepting them, such as the monitoring of driving for insurance “discounts”, etc. don’t want ‘em, don’t accept them.
