Discount Tire Question - What if I.....
Discussion in 'Wheels & Tires' started by 737fixer, Aug 13, 2021.
  1. Aug 13, 2021 at 7:46 PM
    737fixer
    737fixer [OP] New Member
    If I bring wheels into Discount Tire will they put any size tire I choose on? I know if I bring in my truck they seem to lose their minds when it comes to oversized tires. I want to install the Nitto 285/70/18 but don't want to fight with someone over why.
  2. Aug 13, 2021 at 7:49 PM
    Sunnier
    Sunny
    San Diego, CA
    Yes. But they probably won’t let you buy warranty protection and you may have trouble with warranty overall, because you won’t be able to prove the mileage and that tires you bring in are the ones you bought from them.
    Can’t prove it anyway, even on the truck, but getting them mounted on a truck initially… you can bring them in, off the truck, for warranty replacement, and they don’t argue.
  3. Aug 13, 2021 at 8:17 PM
    kidrman
    kidrman New Member
    2020 Tundra CrewMax
    I bought my 285/70 18 from discount and they didn’t flinch. ‍♂️bought wheels too but they knew what truck they were going on and said nothing.
  4. Aug 14, 2021 at 6:03 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Not at all, they deal with lifted vehicles and larger tires all the time. I always upgrade to larger tires and have used DT for many years, never an issue. It if fits, they install it. I have never had any issue with any warranty, I buy the certs and they have replaced tires (larger than stock) and never made a peep about them being larger than stock size or a higher load rating than stock tires.
    Now that could be different based on local laws, like in CA for example. But I have lived in VA and SC and DT in those areas had no issues at all installing larger meats.
    D4x4TRD and pandapro like this.
  5. Aug 14, 2021 at 6:08 AM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    I’ve also used DT no issues and I’ve done it both ways over the years brought my own rims in and I’ve bought rims from them also no problems with warranty either
  6. Aug 14, 2021 at 6:13 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I have the 28/70/18 , and never had any issues with DT.
  7. Aug 14, 2021 at 7:33 AM
    737fixer
    Good to hear. Thought I read in several places that it was an issue because the internet is never wrong. Thanks guys.
  8. Aug 14, 2021 at 7:44 AM
    Sunnier
    Sunny
    San Diego, CA
    @737fixer i realized when I read these other replies, that my reference to warranty claims wasn’t clear. I am referring to “certs”. Tires are stamped with a code that indicates when they were manufactured, so a failure will be covered.
    I meant that a potential problem could be a tire wearing early or something— since those are tied to mileage as well as time, DT could argue it has more mileage than you’re claiming.
    Edit: but I and other truck friends have bought both ways.
  9. Aug 14, 2021 at 7:49 AM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    They record the serial number on tire for warranty purposes and identification.
  10. Aug 14, 2021 at 7:52 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    DT wouldn’t mount 35x12.5x18 on my 8” wide wheels I had at the time, but doesn’t seem like that should be an issue for you. Aren’t you located in AZ? What shop are you going to? I’ve had good luck with the guys at the Discount at Cooper and Warner.
  11. Aug 14, 2021 at 8:00 AM
    Seems like different DT does have some different rules depending on manager.
    I just purchased some used take offs for my truck, took them into DT and purchased the certificate’s. Some people say they won’t do that either.
    Sunnier likes this.
  12. Aug 14, 2021 at 8:05 AM
    Sunnier
    Sunny
    San Diego, CA
    I think you’re right about managers citing different rules for certs. I’ve experienced it once and, if the manager notes anything limiting in the customer’s file, it comes up when the customer file is searched in another store. Luckily, another manager seems to have the same volition to make their own ruling.
    ColoradoTJ likes this.
  13. Aug 14, 2021 at 9:40 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have heard that Wal Mart won't put tires larger then stock on a vehicle but never have had or heard of Discount not doing it.
  14. Aug 14, 2021 at 10:30 AM
    737fixer
    Cooper & Warner just down the street. Will go there.
    Sunnier and TRDFerguson like this.
