Distance till empty is inaccurate.
Discussion in '2.5 Gen Tundras (2014-2021)' started by KMG, Jun 15, 2019.
  1. Jun 15, 2019 at 9:06 AM
    KMG
    KMG [OP] New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    Hello, I have a 2018 and have been pulling my 5th wheel and notice that the miles till empty is off. We have run over 6 tanks of fuel while pulling so the miles per gallon is reading correct at 8.6mpg. When it shows 100 miles till empty we can go 60 miles if we push it. Is there a way to adjust or correct the reading? Thanks
  2. Jun 15, 2019 at 10:37 AM
    Sunnier
    Sunny
    San Diego, CA
    Guys, it's because your gas pump is located in the tank, and needs to be covered in gas. So when you see 0, you're about to go below that.
  3. Jun 15, 2019 at 10:52 AM
    Sunnier
    Sunny
    San Diego, CA
    Yup, exactly. That reserve to keep the pump covered though-- so best to treat 0 as almost real.
    15Yota likes this.
  4. Jun 15, 2019 at 11:34 AM
    KMG
    KMG [OP] New Member
    Kevin
    Yacolt, WA
    Thanks for the replies. I know about the reserve after gauge reads empty. What I'm asking is why is the range till empty function so far off? It has to be a calculation of gallons till empty multiplied by the average fuel mileage. I've been averaging 8.5mpg for 2,400 miles so it should be able to display an accurate distance till empty.
    Pudge likes this.
  5. Jun 15, 2019 at 1:36 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    So, what you're saying is when the truck calculates the distance to empty, it thinks it's getting 14.2 mpg, when you know it's only getting 8.5 mpg from your pump receipts. (60miles/8.5 mpg = 7.1 gallons; 100 miles range/7.1 gallons = 14.2 miles/gallon)
    I've run another vehicle out of gas once using miles until empty range. Too much black majic and uncertainties in the calculation to expect high accuracy. It should be closer than that, but it is what it is. Maybe your dealer can "adjust" it, but I doubt it.
  6. Jun 15, 2019 at 1:46 PM
    15whtrd
    15whtrd Mr. Blonde
    Try resetting the average mpg
    landphil and JohnLakeman like this.
  7. Jun 15, 2019 at 2:36 PM
    JohnLakeman
    Not trying to discourage you, but your expectation may be high. For that whole average mpg/distance to empty calculation to work properly, I have found that you have to fill your tank every time until the gas pump shuts off...once. Then, to protect your charcoal filter, stop, don't top off.
    If you disconnect your battery ground cable, you will zero the average mpg as @15whtrd suggested. It will start over from zero calculating a new average mpg. Expect your distance to empty to be way out of whack until the calculation settles out. He and I believe your truck is using an average mpg from early in it's life (pre-towing) to calculate distance to empty.
    BUT, what I found after disconnecting my battery to upgrade to 2018+ headlights, the average mpg, which was steady at 16.5 previously, settled out at 14.5 afterwards. Do I think the truck is actually getting 2 mpg less because of the new headlights?...not a chance. But, then I never fill my tank completely full, and I suspect that has to happen for the calculation to be ballpark accurate. One of those numbers is bogus, and the only way to know for sure which is to hand calculate...which requires completely filling the tank.
    My advice is don't fret over technology that isn't quite up to GPS accuracy. Do it the old school way: When the gage gets down to 1/4 or 1/8, stop for fuel.
    Ely010606 and 15whtrd like this.
  8. Jun 15, 2019 at 2:45 PM
    KMG
    KMG [OP] New Member
    Kevin
    Yacolt, WA
    We don't rely on it. I use the tripometer and make sure I stop before I go 250 miles which gives me a nice reserve if a station is closed.
    JohnLakeman likes this.
  9. Jun 15, 2019 at 3:28 PM
    I would never let it go near empty; especially if towing and in somewhere I’m not familiar with
  10. Jun 15, 2019 at 3:44 PM
    Twinky
    07 double cab work horse
    Im going to agree with a few of the guys here also. Your truck may be reflecting the average mpg that still has a much larger accumulated miles compared to what you are currently getting.
    You know, 50k miles under normal conditions getting 15mpg. New conditions, hauling ect, 6k miles getting 10 mpg. Just arbitrary numbers but it would probably take a lot more milage under the new conditions before there is a significant impact on the mpg average in total.
    Then again, this might all be irrelevant because you've already did a proper reset and all that jazz.
    Meh...
    15whtrd likes this.
  11. Jun 15, 2019 at 3:58 PM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    FAKE NEWS!:annoyed:
  12. Jun 15, 2019 at 3:58 PM
    TRDProLife
    St.Louis
    Wrong
  13. Jun 15, 2019 at 4:07 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You don't need to disconnect your battery to reset your mpg.
    Just hold down the disp button on the steering wheel for a couple seconds. Op give this a try.
  14. Jun 15, 2019 at 4:11 PM
    Sunnier
    Sunny
    San Diego, CA
    Teach us.
    15whtrd likes this.
  15. Jun 15, 2019 at 4:18 PM
    TRDProLife
    St.Louis
    JohnLakeman, Black Wolf and Sunnier like this.
  16. Jun 15, 2019 at 4:23 PM
    minter66
    minter66 2007 TSS CrewMax
    I'm the opposite with my 07, it is way too conservative. Just finished towing my 19' TT from Texas to Colorado and back. On the way back we were really trying to make Amarillo for a show in Palo Duro Canyon. I went from Espanola, NM to Amarillo, TX on one tank. I hit 0 DTE about 40 miles before Amarillo, and when filling up still had 2.5 gallons in the tank.
    I figured this out when I towed my campter to Matagorda Bay, TX. At 2 miles DTE, I still had nearly 5 gallons in the tank.
    This is causing me to stop and fill up unnecessarily. I could have made the coast and not wasted time filling up.
  17. Jun 15, 2019 at 5:32 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The fuel flowing through the pump is how it cools, there isn’t much heat transfer through the plastic fuel pump “module” housing.
  18. Jun 15, 2019 at 7:39 PM
    Sunnier
    Sunny
    San Diego, CA
    Thanks fellas! I'll stop spread this wrong info. Love me some @ColoradoTJ. The guy drinks and knows things. :cheers:
    FirstGenVol and Black Wolf like this.
  19. Jun 15, 2019 at 8:01 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    8 gallons of reserve
    AgileTundra likes this.
  20. Jun 15, 2019 at 8:20 PM
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
    Does the tundra have a low fuel light? I have a 2019 and have at least 8 gal left when the read out says I only have 16 miles to empty. So technically with the mileage I get of 16mpgx8gal will take me another 128 miles if necessary. That's one hellva reserve.
  21. Jun 15, 2019 at 9:03 PM
    TacoWuzzaTurd
    Scottsdale AZ
    Normal and commonly posted about here
  22. Jun 16, 2019 at 4:46 AM
    JohnLakeman
    Some of ya'll sound like "reserve" is a dirty word. :D
    A favorite shared story with my son is being in the middle of nowhere in my old 86 4Runner, near midnight, approaching El Paso. Nothing out there but rock, dirt, and weeds if you need gasoline. Operators know that and raise their prices between Sonora and El Paso to astronomical levels. The last opportunity for "cheaper" gasoline is Sonora, and from there to El Paso was almost exactly the range of the 4Runner.
    When the bingo light came on, the gage touched the "E" mark, my son reminds me that I uttered the memorable phrase "I hope the two gallon 'reserve' is there". It was, fortunately, but that tank was smaller. :rofl:
    TacoWuzzaTurd and 15whtrd like this.
  23. Jun 16, 2019 at 10:33 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    The only thing that is more accurate than the miles till empty is your local weatherman.
    Bammer, JohnLakeman and landphil like this.
  24. Jun 17, 2019 at 12:31 PM
    1fujifilm
    1fujifilm New Member
    Bear
    19 Tundra Crew
    Once I drive past the "low fuel light" coming on and I drive until it shows zero miles left I have filed up and had 5.8 gallons left.
    Tank holds 38 gallons minus gas pumped of 32.2 gallons = 5.8 gallons left.
    It's your decision from there how far you think you can get.
    Bear
    Sunnier and AgileTundra[QUOTED] like this.
  25. Jun 17, 2019 at 12:48 PM
    AgileTundra
    Thank you for the reply, exactly what I was looking for. I have never let the light come on which is why I asked the question the way I did.
  26. Jun 17, 2019 at 12:54 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Excellent GOT quote.
  27. Apr 19, 2021 at 1:44 PM
    hiker108
    hiker108 New Member
  28. Apr 20, 2021 at 5:40 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    I don't think I have ever been below 1/2 !
