Ditch light wiring with 4 wire switch
Discussion in 'Lighting' started by TylerDurden311, Jun 24, 2019.
  1. Jun 24, 2019 at 4:53 PM
    TylerDurden311
    TylerDurden311 [OP] Paper Street
    2018 Tundra CM
    I am having trouble wiring a 4 wire OEM style switch to a 2 wire harness. There is a red and black coming from the harness. I wired red to red1 on switch. Green to 12v constant( dome lights) with an add a fuse. Black on switch to black on wiring harness. The lights on the switch seem to be working correctly (wording lit up, than when switch is pushed both wording and image are lit)but it is not activating the relay. The lights will work with a toggle switch. Is it possible the switch is bad?
  2. Jun 24, 2019 at 9:12 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    You will still need a relay. The switch will illuminate dimmed when parking/headlights are on but illuminate brighter when it's on.
  3. Jun 25, 2019 at 5:09 AM
    TylerDurden311
    2018 Tundra CM
    I have a relay in the loop, it is just not activating with this switch. It works fine with a toggle switch.
  4. Jun 25, 2019 at 6:16 AM
    TylerDurden311
    2018 Tundra CM
    Did you use an existing relay In The truck or one that was in a provided harness?
  5. Jun 25, 2019 at 7:11 AM
    TylerDurden311
    2018 Tundra CM
    Yes I am disconnecting the Neg. terminal while wiring than hooking back up when I test.
    NewImprovedRon likes this.
  6. Jun 25, 2019 at 8:04 AM
    TylerDurden311
    2018 Tundra CM
    Thank you for your assistance. I appreciate you trying to help. I’m gonna give it another shot in a little while.
