Do CAT Shields cause overheating?
Discussion in 'General Tundra Discussion' started by txtundra311, Apr 9, 2023.
  1. Apr 9, 2023 at 7:36 PM
    txtundra311
    txtundra311 [OP] New Member
    Came across this article about CAT Shields trapping heat & causing overheating on the HONDA Element.
    I realize i have some vents on my CAT Shield but it’s not the same as what they have drawn up as an approved design.
    What’s your take on this, should we have any concerns ?
    https://catshield.com/blogs/news/the-design-process
  2. Apr 9, 2023 at 7:45 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Apr 9, 2023 at 7:56 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    No. I don't see any issues.
    There is plenty of air flow. They as re trying to scare you into buying their specific shield. It's a marketing sham.
  4. Apr 9, 2023 at 7:58 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    txtundra311[OP] likes this.
  5. Apr 12, 2023 at 7:06 PM
    txtundra311
    Ok that’s what i thought…. it didn’t make sense, in article they provide new approved design yet they sell a different design for the tundra. Perhaps it was a design just for the honda element :notsure:
  6. Apr 13, 2023 at 6:40 AM
    Saltyhero13
    Not sure why they show cased that open design but you are probably right about it benefiting other vehicles.
    A few members here have reported slightly elevated surface temps with cat shields, +20 degrees, but relative to cat operating temps it is minor. Cats like to be hot but too early to tell if these shields are hurting anything but I doubt they are damaging the cats.
    94537 likes this.
  7. Apr 13, 2023 at 7:52 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I don't have shields, but I was more concerned with the other stuff under shield operating at higher temps than I was with the cats.
  8. Apr 13, 2023 at 8:00 AM
    I have had my plates for quite some time and absolutely no issues at all with FL heat.
  9. Apr 13, 2023 at 8:19 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Good deal. It can be really hard to tell until you look at the numbers. Do you have liquid-to-air ATF cooler on your Tundra?
  10. Apr 13, 2023 at 9:11 AM
    I have the SG3 and it will give you cat temps.
  11. Apr 13, 2023 at 10:30 AM
    Talon2006
    Talon2006 New Member Vendor
    The biggest difference, based on my popcorn eating and speculation is their early designs were more of a box around the cat that sealed up to the unibody. This entrapped air and heat a lot more then if the top was open.
    Most Tundra cat shields have plenty of air gap at the top of the shield, and frame to let air circulate out.
    Granted, that is just me making an arm chair speculation. I wasn't involved in their design processes, so I don't really know what they did on their first designs.
    They have some pretty good blogs... that Amada Laser is awsome!
  12. Apr 13, 2023 at 10:49 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Most cat shields are like a skid plate. Hard to imagine air getting baked in there. If the shield just covered the cat like a blanket then I would assume it would
  13. Apr 13, 2023 at 2:27 PM
    txtundra311
    Thanks for the input, I actually have your CAT shield Great Product!.....Enjoy the popcorn :thumbsup:
    Talon2006[QUOTED] likes this.
  14. Apr 13, 2023 at 5:23 PM
    2mchfun
    I wouldn't be concerned about the cats running hotter due to the flow of hot exhaust gases keeping the temperature pretty constant. However, the surrounding components are going to be getting a little extra heat applied, especially when slowly moving or stopped. Not a fan of that, so I used expanded metal which also allows me to monitor for leaks and rinse off any road salt residue easily. Saved a bundle too which is always a great thing!
  15. Apr 15, 2023 at 7:17 AM
    huntsonora
    huntsonora New Member
    2006 Toyota Tundra DC
    My only concern is getting weeds or grass caught in them while at the ranch and it causing a fire. For this reason I’ll have to take my chances with the meth heads
  16. Apr 15, 2023 at 8:30 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Highly unlikely as most cars don't have cats as exposed as tundras. Usually they are hidden and tucked away in the engine bay where air flow is minimal.
    Also if there is trapped heat, the tranny is right there, and I still see the same temps as before the shields.
  17. Apr 18, 2023 at 5:42 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    My homemade shield has no air holes and I haven't seen a temp difference the past 2 years, it's the reason I haven't put holes in it yet :notsure:
  18. Apr 18, 2023 at 5:50 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    as an fyi...the cat temp is an interpolation. not an actual sensor reading.
