do I need a relay? simple LED accent bar install
Discussion in 'Lighting' started by InsaneAuto86, Feb 5, 2020.
  1. Feb 5, 2020 at 5:20 AM
    InsaneAuto86
    InsaneAuto86 [OP] New Member
    SE PA
    2020 Tundra SR5 TRD
    Installing these products on an interior switch. Total amp draw is as follows:
    LED accent bar front grill - .61a
    LED pods footwell area - .02a/ea x2 = .04a
    total .65a
    switch is rated 15a
    Need constant 12v, so will run a dedicated wire from battery with 3a inline fuse.
    Do I need a relay or can I run from battery directly to switch?
    What gauge wire is appropriate for the run (approx 7ft battery to dash)? 16g?
    products I intend to install
    light bar
    pods
    switch
  2. Feb 5, 2020 at 6:05 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You only need a relay if you’re using a different source for switched power. for example, you want to use your factory fog lights switch to control a high power light bar that pulls in excess of what the factory wiring is rated for. You’re using the factory wiring simply as a 12v switch to turn the relay on to draw power from the new harness that is connected to the battery.
    If you’re running a new switch and running power to the battery, there is no need for a relay.
  3. Feb 5, 2020 at 6:06 AM
    cmack
    cmack New Member
    AZ
    2018 Burrito
    X2
  4. Feb 5, 2020 at 6:10 AM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    Ok thanks. Obviously, I'm not nearly approachin the draw of the switch.
    16g ok for this? The chart online seemed to confirm
