Do not drive at a constant speed for extended periods.?
Discussion in '3rd Gen Tundras (2022+)' started by ArthurOz, Feb 26, 2024.
  1. Feb 26, 2024 at 7:28 PM
    ArthurOz
    ArthurOz [OP] New Member
    Arthur
    24 Platinum
    In the owners manual, under Break In Tips (page 178 - see below), the guidance amongst other things is not to "drive at a constant speed for extended periods" for the first 1000 miles. I'm flying 600 hundred miles to a dealer in a different region to buy and drive my new truck home. I suppose I'll need to make a lot of stops and avoid using cruise control and adjust my speed regularly so as to follow the break in guidance from the manual.
    How would you comply with this guidance if your first 600 miles were a long drive home from the dealership? Stop every 50 miles? 50mph for 10min, 60mph for 10, 70 mph for 10 and so on?
    Whatever I have to do, I don't really care, as I will be so excited to get this thing. Any day now.
    FROM MANUAL:
    ■Breaking in your new Toyota
    To extend the life of the vehicle,
    observing the following precautions
    is recommended:
    ●For the first 200 miles (300 km):
    Avoid sudden stops.
    ●For the first 500 miles (800 km):
    Do not tow a trailer.
    ●For the first 1000 miles (1600 km):
    • Do not drive at extremely high
    speeds.
    • Avoid sudden acceleration.
    • Do not drive continuously in low
    gears.
    • Do not drive at a constant speed
  2. Feb 26, 2024 at 7:34 PM
    bflooks
    bflooks New Member
    Metrowest MA
    If possible, I'd stay off the highway. Otherwise, fluctuate speeds as mentioned. Don't run the cruise.
  3. Feb 26, 2024 at 7:38 PM
    Speed of vehicle is one thing, speed of engine is another. If you’re driving 70 mph for extended periods to make decent time, shift it into 9th or 8th gear occasionally if slowing down isn’t an option. It will vary the rpm’s to prevent constant running at 1700rpm or whatever it’s cruising in 10th.
    DFS, Kanadakid, Eurodriver and 6 others like this.
  4. Feb 26, 2024 at 7:49 PM
    I would buy a thermal gun if you don't have one already. Your rear differential can get pretty warm when breaking in. This is another reason to stop periodically and take a cat nap. Tell the family you will be back in a week or so...but not longer than 3 weeks :D
  5. Feb 26, 2024 at 8:25 PM
    dogsleds_t100_tundra
    dogsleds_t100_tundra New Member
    '23 Tundra SR5 TRD OffRoad AG and '97 T100 4x4
    275/70/18 Cooper AT3s, Kenwood speakers, Infinity Subwoofer, Kicker Amplifier, Alpine Tweeters, Solargard Ceramic Window Tint, Shellz grill surround, PaintedOEMparts rear bumper panels, Orvis Backseat Protector for K9s, OEM Black Exhaust Tip, OEM Black Tailgate badge insert, OEM black front emblem, Black raised domed lettering on grill and bezel.
    Ditto last year, flew, and returned about 700 miles. Treat yourself to scenic route on way back home, speed changes, occasional stops, soak in scenery, and enjoyed the new ride. Expect a little grease to clean off the wheels when you get home, no sweat. Enjoy!
    Tundrastruck91 likes this.
  6. Feb 26, 2024 at 8:27 PM
    Hella Krusty
    Hella Krusty New Member
    PFFTTT....drive it like you stole it. The value will be the exact same when you sell it. No person on the earth is going to ask if you followed the break in recomendations.
  7. Feb 26, 2024 at 8:35 PM
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    Another break-in recommendation from the manual is to disable the autostop feature to allow the turbos to cool while the engine is running. This is more important after slowing down from highway speeds, or after a sprited drive.
    I disable autostop everytime I start the truck. I don't like this feature. I think it does more harm than good, and uses more gas.
  8. Feb 26, 2024 at 9:09 PM
    I would rather let the gear manufacturers do the talking for me. I have said it many times over the years, but if you want long term performance and a cooler operating differentials (better economy) one might want to pay attention:
    https://www.yukongear.com/blogs/the...ide-ensuring-peak-performance-and-longevity_1
    https://www.sierragear.com/differen...involves,let the differential cool completely.
    https://eastcoastgearsupply.com/ft-1479-new-gear-break-in-procedure.html
    https://www.randysworldwide.com/blogs/breaking-in-ring-and-pinion
    bflooks, Tripleconpanna and RobertD like this.
  9. Feb 26, 2024 at 9:11 PM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    won’t have this option if buying a hybrid. They don’t have the button to disable it. With they did cause it can be annoying when the truck is always shutting off. Also weird to be driving on battery power at low speeds and have no engine sound at all.
  10. Feb 26, 2024 at 10:27 PM
    Ragnarkov
    Ragnarkov New Member
    Stephen
    2021 Silver Sky Metalic Platinum Tundra
    Nothing.... yet.
    What is considered 'extended periods'? I drive on the highway for 10-15 min before I have to get on the off ramp, and slow down, then speed up again, have another 10-15min jaunt were i fluctuate the speed slight, but I certainly don't go for 30min or even an hour at a time. we are talking 15km or so between changes. sometimes 15-20km an hour difference, sometimes less.
    Would this be safe for the break-in period?
  11. Feb 27, 2024 at 1:01 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Thats how I thought about it at first.
    Now I just stop worrying about it. Toyota been building hybrids for a long time, including turbocharged engine hybrids, and everything is just fine. They know what they're doing
    Hella Krusty and Mattedfred like this.
  12. Feb 27, 2024 at 4:02 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Nitro has very similar instructions, as well as a towing break-in process.
    Direct from their install instructions:
  13. Feb 27, 2024 at 4:33 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    You can use the highway, no problem. Follow this schedule:
    - merge onto highway
    - occupy left hand lane
    - speed up to the posted limit and then slow down to 75% of limit within 2 minutes
    - repeat this cycle until you reach your destination
    SC4333, Mattedfred, snivilous and 2 others like this.
  14. Feb 27, 2024 at 6:21 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Do not apply the brakes, though. Don't want to tip anyone off that you have a new vehicle (or that you may be slowing down). I'm sure they'll understand.
    hagrid[QUOTED] likes this.
  15. Feb 27, 2024 at 6:23 AM
    centex
    centex New Member
    Bingo. Followed this procedure with every new vehicle and have never had an issue.
    Also, the recommended break in period has been a new car thing for the last 50+ years. It’s not new.
    Hella Krusty[QUOTED] likes this.
  16. Feb 28, 2024 at 6:20 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    We went on a 3000 mile road trip when my truck only had 400 miles on it. It was the first time I was glad my wife has a small bladder, so the frequent stops didn't bother me.
  17. Feb 28, 2024 at 10:33 AM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    For best results, don't read the owners manual.
    Hella Krusty and centex like this.
  18. Feb 28, 2024 at 11:17 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    So shutting off a gasoline engine uses more gas than letting it idle? That's a hard statement to get on board with.
    doublethebass likes this.
  19. Feb 28, 2024 at 11:48 AM
    DRP
    DRP Old Member
    Dave
    If he figured out a way to make it use more gas when the engine is shut off, maybe he can get a parent on the idea?:eek2::thumbsup:
  20. Feb 28, 2024 at 1:27 PM
    topdec
    topdec New Member
    I think the fuel savings depend on various factors such as the duration of the stop, the frequency of stops, and the efficiency of the engine. For very short stops, the fuel savings from shutting off and restarting the engine may be minimal, and there could be a small additional fuel consumption during the restart due to the energy required to crank the engine.
    Where I drive most of the time, the stops at intersections are quick.
    I may be wrong, but this is just my experience. Sorry for going off on a tangent on this thread.
  21. Feb 28, 2024 at 2:07 PM
    Matt2015Tundra
    2023 1794 CrewMax
    The auto stop/start "feature" is saiid to save 5-7% on fuel economy, if you do all stop and go driving.
    I've heard and read all the claims about heavier duty starters and flex-plates that are supposed to be engineered to handle the additional work load of repeated start/stop cycles. But I'm old-school and still believe the majority of engine wear happens from starting the engine, not fuel dilution while idling.
    My conclusion....turn that shit off every time I start my truck.
