Does mine have flex fuel or no?
Discussion in '2.5 Gen Tundras (2014-2021)' started by tsgoodwin23, Dec 4, 2022.
  1. Dec 4, 2022 at 5:24 PM
    tsgoodwin23
    tsgoodwin23 [OP] New Member
    2020 tundra TRD Sport
    I read that if the 5th letter of your vin is a Y that means it’s a non flex fuel truck. But my gas cap says it takes that e85 crap? I’m trying to decide if I want to trade it for another because at 30k miles, I’m hearing what sounds like pinging when it’s under load at low RPM’s and some whistle sound when you coast around 2k RPM’s.
  2. Dec 4, 2022 at 5:28 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Mine is a flex and the 5th "letter" is a W.
    Patch999 likes this.
  3. Dec 4, 2022 at 6:42 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I believe the best way to know is to look under the hood at the stickers that identify the engine. 3UR-FE is regular gasoline, 3UR-FBE is flex fuel.
  4. Dec 4, 2022 at 6:52 PM
    AZBoatHauler
    So.Arizona
    This checks out for me. Also W for 5th of VIN.
  5. Dec 4, 2022 at 6:54 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    If you want to share your VIN I came run it through the official Toyota VIN decoder. You can also with a free account at Toyotaowners.com It will say on there
    TXCarol7304 likes this.
  6. Dec 4, 2022 at 8:42 PM
    tsgoodwin23
    I actually have that and my truck is on it but I don’t see where it says flex fuel or not.
  7. Dec 4, 2022 at 8:42 PM
    tsgoodwin23
    So yours is not flex fuel?
  8. Dec 4, 2022 at 8:44 PM
    AZBoatHauler
    So.Arizona
    Mine is a flex. 3UR-FBE code under hood.
  9. Dec 5, 2022 at 7:02 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I always go to the website, login and go to the vehicle specs section. There you can input a VIN and it will give you the details of that vehicle.
    Here is a random VIN I got off Autotrader that is a Flex fuel truck.
  10. Dec 5, 2022 at 7:33 AM
    tsgoodwin23
    Oh mine doesn’t say flex fuel then. I wonder why the gas cap says it is then? And now I wonder if something is wrong with it because of those noises that other 2020’s don’t make
  11. Dec 5, 2022 at 7:39 AM
    Flex fuel engines were discontinued along with the smaller V8 after the 2019 model year. There shouldn't be any 2020+ with flex fuel.
    Doxiedad likes this.
  12. Dec 5, 2022 at 8:02 AM
    tsgoodwin23
    Well I evidently went to a dumbass dealer but my gas cap also says it takes the e85 garbage so I don’t know what the deal is with that
  13. Dec 5, 2022 at 8:12 AM
    My guess would be that the cap was replaced, or just a mix up.
    Jaypown and AZBoatHauler like this.
  14. Dec 5, 2022 at 8:39 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Or maybe after 2019 they all can use E85?
  15. Dec 5, 2022 at 8:39 AM
    No.
    AZBoatHauler likes this.
  16. Dec 5, 2022 at 11:41 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Toyota writes it in the owner's manual under "8-1. Specifications" that slight knocking under acceleration is normal. My truck is extremely quiet so I notice a lot of engine noise and what sounds like light pinging at low RPM under load, I think a lot of it is just intake noise.
  17. Dec 5, 2022 at 11:48 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    This sounds like the most realistic thing that happened.
    OP, just take a sharpie and cross out the E85 part on your gas cap, drink a beer and enjoy the rest of your day :thumbsup:
