Does my truck have the fake engine noise?
Discussion in '3rd Gen Tundras (2022+)' started by AWDDude, Dec 29, 2022.
  1. Dec 29, 2022 at 4:38 PM
    AWDDude
    AWDDude [OP] New Member
    2023 Tundra Limited - Crew Max TRD Off Road 4x4
    So I have a 2023 limited with TRD Off-Road package, which comes with the 14in infotainment display, but not the JBL upgraded audio. When I give the truck any throttle I hear a decent amount of rumble in the cab that I do not hear outside the vehicle. I assumed this was the fake engine noise everyone talks about. I purchased the carista obd2 dongle and hooked up it all up and went to customize, there are a tons of options listed, but nothing regarding engine noise, in fact there isn't even a "Chassis and Engine" section listed. I was able to successfully disable all the seatbelt dings, and enable the window rolldown with fob long press.
    Is this a Carista problem, or does my truck not have that feature at all?
    Jongie123 likes this.
  2. Dec 29, 2022 at 4:39 PM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    Good question. Waiting for an answer
  3. Dec 29, 2022 at 4:57 PM
    Vick_Lagina
    Vick_Lagina New Member
    I think the fake engine noise comes with the premium JBL audio system. If you don't have that, you don't have the fake engine noise.
  4. Dec 29, 2022 at 5:10 PM
    firehawk003
    firehawk003 New Member
    I was under the impression it was the limited and above trims. Interesting. I did not have it in my sr5, but had it on my platinum. It was the first thing that had to go. It was like listing to a twin engine boat that was not synced.
    Retired...finally and Patch999 like this.
  5. Dec 29, 2022 at 5:24 PM
    TundraWorkHorse
    Looked at some youtube videos and apparently only the dealer can do it with there scan tool through the OBD11 connection.
    The dealership tech can hook up their scan tool to the OBD II port. Then, going into the settings, they will find the following: Active noise control > utility > customize > others > ANC/ESE.
    Turning off both ANC/ESE will remove the fake exhaust note.”
    Update found a video where you can do it with the Carista app.
    https://youtu.be/V4wM7A2SLS0
    Black Wolf likes this.
  6. Dec 29, 2022 at 6:00 PM
    TundraWorkHorse
    After watching the video , i will keep the growl noise . Carista tool is a very basic tool but im sick and tired of monthly fees. Rather just buy the d7 diagnostic tool instead .
  7. Dec 29, 2022 at 10:43 PM
    AWDDude
    yeah but you only need to have an active subscription to make changes to the settings. once you cancel the subscription, the settings are still the way you left them. Plus you get a free month subscription when you buy their obd2 dongle.
  8. Dec 29, 2022 at 10:45 PM
    AWDDude
    Yeah I tried Carista but it doesn’t have the option listed for my truck.
  9. Dec 30, 2022 at 5:05 AM
    ThomperBeThompin
    ThomperBeThompin New Member
    I have a 2023 Limited with the JBL upgraded sound system, so it came with the fake engine noise. I already had the Carista OBII device from my previous vehicle. I hooked it up, bluetoothed to my phone, and was able to play with all the settings. I turned off the fake engine noise (there's a noticable difference and I actually didn't mind the fake noise), changed the turn signal settings from "3-blinks" to 4 (you have a selection of about 2 - 8 ish), and finally I enabled the feature where you can roll down all windows from your key fob. You just press the unlock button 3 times and hold, then it rolls down all windows. Great for walking to your car on a hot sunny day. There's a bunch of other things you can change too regarding lighting (exterior and interior), chimes, etc.
    Ponderosa_Pine likes this.
  10. Dec 30, 2022 at 9:05 AM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Can Carista or the dealer adjust the fake engine sound to be lower? I'm on the fence whether I want it or not, but if it could be turned to maybe half volume I'd keep it. Just asking.
  11. Dec 30, 2022 at 9:08 AM
    ThomperBeThompin
    No way to "reduce" the volume that I know of - can only turn it on or off. I wanted the same thing, to reduce it. I'll likely leave my turned off, it doesn't sound terrible, just quieter.
  12. Dec 30, 2022 at 9:12 AM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I can't speak for the Limited trim, but for what it's worth, there is zero rumble noise in my Plat. with that stupid fake sound turned off. I'd assume it should be the same for your trim.
  13. Dec 30, 2022 at 9:26 AM
    Breathing Borla
    Northern Illinois
    ya this
    went I tested the platinum that fake noise really seemed out of place, its didnt even really match up with the tach.
    its going off ASAP when I get mine and Ill roll with the silence.
    having owned V8s with borlas , it sounded stupid anyway as far as V8 throat goes
  14. Dec 30, 2022 at 10:17 AM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    You only need to turn off ESE (Engine Sound Enhancement) to get rid of the fake engine noise. You should actually leave ANC (Active Noise Cancellation) on as it helps keeps the cabin quieter.
    Breathing Borla likes this.
  15. Dec 30, 2022 at 4:05 PM
    xc_tc
    xc_tc New Member
    If there is a big plastic JBL module that under your driver’s seat, you have the upgraded JBL system with the engine sound enhancement. If there isn’t anything there, you don’t have ESE and that’s why you can’t find anything in Carista.
  16. Dec 30, 2022 at 4:07 PM
    My 5.7 didn't need it......
    Piney and Black@Blue19 like this.
  17. Dec 30, 2022 at 4:20 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I can’t tell a difference!! I have no idea why they would even do that!
  18. Dec 30, 2022 at 6:44 PM
    firehawk003
    I can’t figure it out. It sounded so fake. The dealer had not ever turned one off when I asked them to but they were able to figure it out.
  19. Dec 31, 2022 at 6:39 AM
    Perpendicular
    Perpendicular New Member
    Paul
    Austin, TX
    2023 Capstone
    So, I traded my 23 Limited in on a 23 Capstone this week. The Limited had the 14" screen, but no JBL option. I did not have the Enhanced Sound option in the Carista app. On the Capstone, JBL is standard and with Carista it now has the option to turn it off. JBL is apparently the system that provides the v8 growl. Yes, turned that off on mine as well :)
  20. Dec 31, 2022 at 6:42 AM
    Deer Hunter likes this.
  21. Dec 31, 2022 at 6:50 AM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    Yes your tundra has fake exhaust sounds pumped into the cab from the speakers because souped up v6s sound like s*** and nobody wants to hear that
    Black@Blue19 likes this.
  22. Dec 31, 2022 at 6:55 AM
    FO LO
    FO LO New Member
    Straight turbo 6.7s sound good deleted with lope tune but ttv6 just needs to be quiet imo
  23. Dec 31, 2022 at 7:44 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Fake engine noises make the baby Jesus cry.
  24. Dec 31, 2022 at 8:51 AM
    FO LO
    FO LO New Member
    Yessir illegal in the south
    Gene_in_FL likes this.
  25. Dec 31, 2022 at 8:52 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Fake engine noise is like turning on a porn in the background so your love life sounds better.
  26. Dec 31, 2022 at 9:02 AM
    TaquitoBandito
    Joel (AKA Bif)
    I thought I had to subscribe to your OnlyFans page to get this kind of advice. :annoyed:
    Hightide[QUOTED] likes this.
  27. Dec 31, 2022 at 9:03 AM
    Hightide
    Abalama
    Magic School Bus
    That’s for the advice with that noise in the background.
  28. Dec 31, 2022 at 10:09 AM
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
  29. Dec 31, 2022 at 11:32 AM
    Ozcomm
    Ozcomm New Member
    Dean
    2021 TRD Pro
    FAKE ENGINE SOUND?!?! Yet ANOTHER reason not to like the gen 3!
  30. Dec 31, 2022 at 1:51 PM
    FO LO
    FO LO New Member
    How much does Toyota charge to add the sound of mud tires to augmented v8 sound from the radio??
