Dongar Dascam Rearview Mirror USB adapter users step inside
Discussion in '2.5 Gen Tundras (2014-2021)' started by Black, Jan 1, 2022.
  1. Jan 1, 2022 at 4:30 PM
    Black
    Black [OP] Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    So I have read a number of folks are using the Dongar with their Tundra even though it says for Tacomas.
    Does the back of your mirror look like this and do you just pop that tab off covering the wire?
  2. Jan 1, 2022 at 4:51 PM
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    My 2021 does not look like that.
  3. Jan 1, 2022 at 5:00 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
  4. Jan 1, 2022 at 5:01 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    My 2020 doesn’t look like that. I just had a cable going into the mirror. I simply unplugged it and stuck the dongar in line. You may want to disconnect yours to verify the plug looks like this before buying.
  5. Jan 1, 2022 at 5:42 PM
    CGP
    CGP New Member
    Looks like your have aftermarket rear view mirror.
    Doxiedad likes this.
  6. Jan 1, 2022 at 9:27 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    While the mirror is different, my mirror mount looks exactly like that. And, yes, the cap just pops off (pull straight down), fully exposing the wire. I hang my radar detector from that arm, so stored the cap away for some later time.
  7. Jan 1, 2022 at 9:31 PM
    Buhockey22
    Buhockey22 New Member
    Marc
    20 Cement LTD CM
    AJT, Bed Lights, Tailgate Lock, Intake
    How does it work? I read good and bad things about it…..
  8. Jan 2, 2022 at 7:54 AM
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    Really like mine on my 2020 tundra. Made the camera install super easy. Next summer when I hook up my rear I might just hardwire both cameras and set up to work on motion.
    Buhockey22 likes this.
  9. Jan 2, 2022 at 10:20 AM
    Black
    This is what I was hoping. Tried a little force on it but did not want to try too hard till someone else confirmed it just pops off
  10. Jan 17, 2022 at 5:10 PM
    Black
    Yup that little cover just pops off with a little force. Used a interior trim tool and it popped right off.
    Unplugged the harness and popped the Dongar in and the DashCam is rolling!!
  11. Jan 17, 2022 at 5:36 PM
    yonquixote
    yonquixote New Member
    ‘21 TRD Pro CM Lunar Rock
    Works well. Easy. Garmin Tandem works well as well. Well….
  12. May 1, 2022 at 5:25 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    I bought directly from your link and the adapter doesn’t work on my mirror. My connectors are 14-pin, not 12. Yes, I should have checked first! I have a 2016 CrewMax with SR5 upgrade, not sure why mine is different from so many others I’ve seen on here, but if anyone can point me in the right direction I’d very much appreciate it, the Dongar website and Amazon are sold out.
  13. May 1, 2022 at 7:19 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    Check the other end of that cable it will match up. I thought the same thing when I got mine. I will try to get a picture of what I am talking about tomorrow.
  14. May 1, 2022 at 7:31 PM
    CoffeeAddict
    2016 Tundra CrewMax
    Closer to the mirror? Well dammit I sent mine back already, lol. And Amazon is out of stock now.:annoyed:
    jhardy1979[QUOTED] likes this.
  15. May 1, 2022 at 7:32 PM
    jhardy1979
    Justin
    Yep
  16. May 1, 2022 at 7:34 PM
    CoffeeAddict
    2016 Tundra CrewMax
    This is one of those kick yourself moments I guess, thank you for the info though. I *JUST* dropped it off for a UPS return yesterday after it rode around in my truck for a couple weeks or more.
  17. May 6, 2022 at 11:30 AM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I love mine. Works as advertised, just a bit pricy to bring into Canada.
