Dongar Pro dash cam adapter
Discussion in '3rd Gen Tundras (2022+)' started by ArmygreenTRD, Dec 5, 2024.
  1. Dec 5, 2024 at 9:03 AM
    ArmygreenTRD
    ArmygreenTRD [OP] New Member
    2022 Army Green TRD, SR5 DC
    Has anyone used the Dongar Pro? https://dongar.tech/products/dongar-pro. I asked them when the low voltage cutoff activates and they stated “We do not know the specific voltage where the low power cut-off activates. However, it is no lower than 11.4V and might be a tad higher. This is based on the general idea that 11v and below is too weak to rely on”. Would 11.4V cause a problem? Too low to start the truck or other issues? Trying to determine if this will work or use the Viofo HK4 ACC hardwire kit https://www.viofo.com/products/viof...et-fuse-for-a329-a229-a119mini2-a139-t130-wm1 that allows selectable voltage cut off. Thoughts/ experiences? TIA.
  2. Dec 5, 2024 at 9:32 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    unbelievable that they sell something, advertising a feature but dont know specifics. I'd stay away from that for sure.
  3. Dec 5, 2024 at 11:30 AM
    ArmygreenTRD
    That’s what I thought. How could you not know your products specs!? They say no lower than 11.4V, maybe higher, but no less than 11V. Holding on this until they provide specifics.
