Door logo lights
Discussion in '3rd Gen Tundras (2022+)' started by offshore2005, Jan 29, 2023.
  1. Jan 29, 2023 at 6:01 PM
    offshore2005
    offshore2005 [OP] New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
  2. Jan 29, 2023 at 6:21 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2022 Tundra Platinum
    That’s pretty cool. Is there option for it to say Tundra? Also does the light itself still work? Plug and play?
  3. Jan 29, 2023 at 6:22 PM
    Taco-Spike
    Two Trucks
    I want to say I’ve seen tundra / Tacoma ones all over eBay / Etsy/ alibaba.
    offshore2005[OP] likes this.
  4. Jan 29, 2023 at 6:23 PM
    offshore2005
    TEXAS
    It’s a plug and play and the only one I found is the photo I posted. It will look just like the photo.
  5. Jan 29, 2023 at 6:26 PM
    offshore2005
    TEXAS
    The ones I found that you can customize stick onto the side of your door and you have to charge them or change the batteries. I wanted a factory plug and play look.
    Taco-Spike[QUOTED] likes this.
  6. Jan 29, 2023 at 6:28 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    Does the light itself still work or is it only an image on the ground
  7. Jan 29, 2023 at 6:31 PM
    offshore2005
    TEXAS
    Just the logo but there is still light on the ground. I feel more than the factory. I honestly never even noticed the light was there before I changed it out. I was cleaning my truck last week and saw the light and started looking for a logo/light to replace it with.
    Sean492 likes this.
  8. Jan 29, 2023 at 6:41 PM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    That is pretty cool. I have a 2014 and don't have a current light at the bottom of the door to put in a plug and play. I am always looking for cool ideas to add to my truck though.
  9. Jan 29, 2023 at 9:26 PM
    worksjo
    worksjo New Member
    2023 Tundra SR5 Off Road
    Has anyone tried to do these replacements on the SR5? I looked at my door and it looks like it’s a red reflector not an actual light in OEM form. I wondering if the terminated wires are in there behind the reflector if I pop it off.
    ByeF150HelloTundra likes this.
  10. Jan 30, 2023 at 4:46 AM
    offshore2005
    TEXAS
    Takes a second to pop it off and check but I doubt they are there.
  11. Jan 30, 2023 at 7:47 AM
    worksjo
    worksjo New Member
    Right, I just didn’t want to break something if it had been confirmed. I popped it off this morning and as expected nothing behind there:(. I got excited for a second when it popped off and the lens is molded with the wire terminal area but nothing is actually in there.
    Soflo likes this.
  12. Jan 30, 2023 at 9:33 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    The wife's Highlander has the logo lights (factory) on the mirrors. Shines "Highlander" on the ground when you approach the vehicle. Pretty cool
    bulldog93 and offshore2005[OP] like this.
  13. Jan 31, 2023 at 4:17 PM
    TUNDRA-TY
    TUNDRA-TY Winter SUCKS!
    Tyler
    Tricities, WA
    23 SR5 4WD CMSB CSM
    That's pretty cool. Plug and play?
  14. Jan 31, 2023 at 4:24 PM
    offshore2005
    TEXAS
    Yes. It is but I tapped the connection together just to make sure it stays in place.
  15. Jan 31, 2023 at 4:25 PM
    TUNDRA-TY
    Tyler
    Tricities, WA
    23 SR5 4WD CMSB CSM
    Sweet very cool cheap mod!
  16. Feb 1, 2023 at 5:50 PM
    Fxclm5
    Fxclm5 New Member
    mayan likes this.
  17. Feb 1, 2023 at 5:54 PM
    TUNDRA-TY
    Tyler
    Tricities, WA
    23 SR5 4WD CMSB CSM
    Because they knew you'd still buy it...LOL
    Mattedfred likes this.
  18. Feb 1, 2023 at 6:10 PM
    worksjo
    worksjo New Member
    Same here, some of the choices they made to differentiate the trim levels are so stupid and annoying.
    Fxclm5[QUOTED] and raylo like this.
  19. Feb 1, 2023 at 6:36 PM
    T315
    T315 New Member
    2022 Tundra Crewmax TRD Offroad
    oops, i bought these lights without checking if my SR5 TRD OR has it. lol
  20. Feb 1, 2023 at 6:39 PM
    T315
    T315 New Member
    To be fair, I don't think people check to see if a door has courtesy lights when buying a car/truck. People start to assume these are standard features, same with backup cameras and power windows.
    mayan, raylo and TUNDRA-TY[QUOTED] like this.
  21. Feb 1, 2023 at 6:44 PM
    worksjo
    worksjo New Member
    I almost did too. BUT now that you’ve ordered them, you can figure out the simplest and cleanest way to wire them in for us. Come one do it for the team.
    raylo likes this.
  22. Feb 1, 2023 at 7:08 PM
    DimaA
    DimaA New Member
    Dmitriy
    WA
    2022 toyota tundra platinum
    K&N air filter. Front windows tint, RC front leveling kit.
    I bought 4 of these light for my truck, went to install them and realized that only front doors have lights not the back ones. Now I have 2 extra
  23. Feb 2, 2023 at 4:02 AM
    nodak67
    nodak67 New Member
    JR
    in this day and age where everything is lower volume (from parts suppliers), a simple wire harness that was nothing to install and waste a little money on in the long run wasnt an issue. now a days, saving a wire harness on 1 truck means you have it for a higher trim level and more profit in the long run.
    the old days where everything was pre wired regardless if you had/paid for the feature is long gone even for toyota.
  24. Feb 2, 2023 at 7:19 AM
    yooperbikemike
    yooperbikemike New Member
    2022 SR5 TRD OR Premium CM 5.5
    Is that available with the bat signal?
  25. Feb 2, 2023 at 8:00 AM
    BroMMack
    BroMMack New Member
    My limited is still shipping, so I can't check for myself. Are there only two door lights on the truck, one on the driver and the other on the passenger? Are there any on the back doors?
  26. Feb 2, 2023 at 8:02 AM
    raylo
    raylo not so new member
    Frederick, MD
    Probably a fuse tap and splice tap the door pin switch circuit for ground. Or tap the door pin switch circuit for 12v. Need to see the schematic.
  27. Feb 2, 2023 at 4:25 PM
    DimaA
    DimaA New Member
    Dmitriy
    WA
    I have platinum and there is only two door lights, driver and passenger doors. Back doors don't have them
  28. Feb 2, 2023 at 6:06 PM
    BroMMack
    BroMMack New Member
    Thanks, that's what I suspected. I ordered the four pack of these for my incoming truck, so I guess I will have a couple of extras.
  29. Feb 8, 2023 at 10:59 AM
    Silver23
    Silver23 New Member
    2023 Silver 1794 TRD
    I added these lights yesterday. Maybe took 10 minutes for installation. I never really noticed the factory lights before. Now when you open the door, you definitely notice it. Looks cool too!
    Crazycalvin and offshore2005[OP] like this.
  30. Feb 8, 2023 at 11:12 AM
    gmotoring
    gmotoring New Member
    Orange County
    2023 Tundra SR5 4x4
    Will never install TRD branded stuff on my Truck
    Dang, SR5 owner, no wires for the light.
