Door open safety lockout bypass
Discussion in '3rd Gen Tundras (2022+)' started by nodak67, Jul 6, 2023.
  1. Jul 6, 2023 at 5:13 AM
    nodak67
    nodak67 [OP] New Member
    JR
    tried this the other day, actually worked but man does the truck beep like mad when you do it. also throws a warning on the center dash display
    in case anyone wants or needs this procedure.
  2. Jul 7, 2023 at 6:37 PM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    I also found that when backing with door open, once park brake sets, simply press brake pedal then release park brake with the park brake switch then it will allow you to continue to back up. Just as you said though the thing will beep at you.
    AZTREK likes this.
