Welcome to Tundras.com!
Quick Links:Pulleys and play - how much is normal?
Leveling 2004 SR5 4WD Double Cab -- Lowering Rear Instead of Lifting Front
Coolant Leak - Bypass pipe O-ring
Hydraulic arms for tailgate to GENTLY lower it.
Lower spare tire with Tailgate down - camper installed in bed
Changing timing belt on 2005 V-8, what else would you replace?
Door panel recover easy DIY
Discussion in '1st Gen Tundras (2000-2006)' started by RR60, Dec 16, 2023.
