Door seals? Where to get and Difficulty level
Discussion in '1st Gen Tundras (2000-2006)' started by Motopilot, Feb 9, 2021.
  1. Feb 9, 2021 at 1:01 PM
    Motopilot
    Motopilot [OP] New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    Anyone changed these? How difficult? Doesn’t look like it would be...also where to get new door seals? Suggestions
  2. Feb 9, 2021 at 1:18 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Toyota will have quality replacements, but Toyota parts are not cheap. https://parts.toyota.com/ they will also have good schematics to let you look over the seals and weatherstrips to see what you need to order.
    With door seals and similar rubber parts I try and go with OEM if they are available, then aftermarket if that is the only option. OEM always fits and works better and seals and weatherstripping is something you want to do once, have no issues or air/water leaks.
    twistedcricket and Motopilot[OP] like this.
  3. Feb 9, 2021 at 4:16 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I hope you're sitting down when you look up the price of those door seals on the Toyota web site. I don't recall what the cost is, but I do recall that it's insultingly high.
  4. Feb 9, 2021 at 4:39 PM
    Professional Hand Model
    Hand Protectors
    Not knowing what condition are your door seals I’d recco remove and cleaning them with warm soapy water. Clean the metal body tracks as well. Once dry you can spray/rub AeroSpace 303 on the gaskets and they will look like new restored. The clean gasket will fluff up a little with the love giving you a quality seal and quiet cab.
    If they are ripped and torn then you need new ones.
  5. Feb 9, 2021 at 4:44 PM
    Motopilot
    Josh
    NC/FL
    Unfortunately ripped and torn in some places I’ll take a few pics tomorrow in the light and get the consensus
  6. Feb 10, 2021 at 3:44 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I think I paid around $110 a piece for new ones through @Roman . I tried to find something else that would be close but didn't have any luck.
    Installation was pretty easy, easier if you have a helper and if it's warm.
    Rex Kramer and Motopilot[OP] like this.
  7. Feb 10, 2021 at 7:17 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    If it’s the full door seal on the frame then you will need the correct one for your interior color as a bit of colored rubber trim is attached as well.
    Motopilot[OP] likes this.
  8. Feb 10, 2021 at 7:23 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    I just replaced the 2 front window outer seals... Not cheap. The door seals on mine need replaced as well, too scared to look up price just yet.
    Best thing to do is get the factory part numbers then shop around online. Different dealers charge different amount. eBay worth checking as well.
  9. Feb 10, 2021 at 8:12 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I think I take better care of my door seals than I do of my paint! LOL
    I use a few squirts of 303 Protectant on a corner of a rag at least once a week!
    Even the 'under-door' seals as well.
    Please keep us posted if you do a remove and replace.
  10. Feb 10, 2021 at 8:19 AM
    Motopilot
    Josh
    NC/FL
    Mine are in pretty good shape in terms of not being hard or dry rot...just torn on the top outer seal...almost like keys got locked in the truck they tried to get something slid down in there to punch the electric lock...my best guess. Pics coming in a minute.
  11. Feb 10, 2021 at 8:30 AM
    Motopilot
    Josh
    NC/FL
  12. Feb 10, 2021 at 8:50 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    That looks like exactly what happened . . . you can see the paint's scraped in the 1st photo.
  13. Feb 10, 2021 at 9:23 AM
    Captain Tenneal
    Captain Tenneal New Member
    NNV
    2005 SR5 Double Cab Off-Road Package, Sunroof
    Bilstein 5100 - 1 groove up
    We need a group buy for door seals. I have a 5 inch chunk or rubber missing on the B pillar driver's side, waist high.
  14. Feb 10, 2021 at 9:32 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Pretty impressive video . . . . if you could find a 'section' of the same seal . . . 'junkyard' perhaps?
    (BTW I used this stuff to re-attach the rubber boot at the front of my Leer shell on my last truck, and it worked killer)
    https://www.youtube.com/watch?v=_C-3_pJNntc
  15. Feb 10, 2021 at 2:54 PM
    Hand Protectors
    Feather Duster Approved!
    HBTundra[QUOTED] likes this.
