Door threshold/sill/trim easy fix
Discussion in '1st Gen Tundras (2000-2006)' started by Teutonics, Aug 13, 2021.
  1. Aug 13, 2021 at 7:45 PM
    Teutonics
    Teutonics [OP] BestGen Member
    2005 DC SR5 4WD
    I searched the forum to see if this had been posted before, but didn't find it so here's an easy fix that I came up with...
    The door sill trim pieces on all four doors of my DC were loose and would get kicked out of place and rattled. I pulled up the pieces to find that the tabs/ears were broken off of most of the mounting points... like this:
    The fix is to use the license plate type inserts in the existing holes. You'll need 14 to do the whole DC (4 for each front door sill and 3 for each back door... maybe less for AC?) and they can be ordered as "1/4 (#14) License Plate Nuts", such as from Amazon here:
    https://www.amazon.com/dp/B08R2WC6BK
    You'll need to trim each mounting post down slightly to allow for the thickness of the insert. I trimmed each one down so that it was flush with the support webbing. I used a cutter (pictured), but the plastic is soft so you could probably just use a razor knife and work it by hand. Here is the before:
    And after:
    Now insert your nylon nuts into the mounting holes. There are four on each front door and three on each back door:
    They can be adjusted left/right slightly, so I started at the mating side to make sure it was nice and tight against the kick panel trim, and worked towards the back of the truck from there:
    Nice and snug and secure! Hope this helps someone and saves having to buy new trim pieces!
  2. Aug 13, 2021 at 8:45 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Thank you for this, this is a thing that has been driving me crazy for years.
  3. Aug 14, 2021 at 5:24 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Nice Save ! Thank You !
  4. Oct 27, 2024 at 12:25 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I'm bumping this thread just to see if anyone has a better solution.
    i'm about to be attacking the interior and this is really annoying on my driver side
  5. Oct 27, 2024 at 2:27 PM
    Teutonics
    2005 DC SR5 4WD
    Three+ years later and they’re still as secure as when installed.
    Mustanley, shifty` and Weagle like this.
  6. Oct 27, 2024 at 2:28 PM
    Weagle
    Prattville, AL
    Good to hear. I just wanted to double check before I cut off that plastic on the door jamb. Already have enough ordered for all of the door jams, even though the ones on the back are still mostly OK
    Great thinking and great solution. Better than the original design
    shifty` likes this.
  7. Dec 22, 2024 at 3:40 PM
    B888s
    B888s New Member
    Brandon
    Bakersfield, CA
    2000 TRD Off-Road SR5 4x4 Access Cab
    Original owner!
    Thanks for the tip! Just fixed up my son’s truck using this.
    Teutonics[OP], shifty` and Weagle like this.
  8. Dec 23, 2024 at 6:27 AM
    Weagle
    Prattville, AL
    It is better than from the factory, IMO
    it's like using the stud in a wall versus using a sheet rock anchor
    Teutonics[QUOTED][OP] likes this.
  9. Dec 23, 2024 at 6:28 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    This thread should be stickied
    Fragman and Weagle like this.
  10. Dec 23, 2024 at 6:57 AM
    Added to the mega under interior or something. Paging @shifty`
    Weagle likes this.
  11. Dec 23, 2024 at 7:09 AM
    FishNinja
    Lee
    06DC2wd
    I also think it should be added those plastic "license plate nuts" are useful for a number of body panels/ random tid bits on our trucks.
    Weagle likes this.
  12. Dec 23, 2024 at 7:53 AM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    This is an excellent tip.
    Weagle likes this.
  13. Dec 23, 2024 at 12:24 PM
    Definitely, I need to figure out some keywords to include with the link to drop it in there. “Door plastic sill plate fix”?
    Definitely and I absolutely plan to figure out a way to improve our license plate plastics to use those damn things for my license plate. I intend to work on it after the holidays. Got some good ideas, just need to get my jumper plastics off and take some measurements to figure out which square punch to use to expand the holes. I think the pre-existing holes will make the perfect guide for a square punch.
  14. Dec 27, 2024 at 2:13 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    Damn muchos gracias amigo. I bent a few of mine as well
    Teutonics[OP] likes this.
  15. Jan 28, 2025 at 6:30 PM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    Huge thanks to @Teutonics , this worked great on my first gen that I’m restoring.
  16. Jan 28, 2025 at 9:23 PM
    DBombs
    DBombs I Like Old Trucks
    NE Atlanta
    2006 Tundra DC SR5 V8 4x4 TRD
    While you have the screws out, a little spray paint on the screw head will spiff it up nicely. Usually they are pretty cruddy. Take a cardboard box and stick the screws in the cardboard so they stand up. Then hit with spray paint. Original was a shade of black, or you can color match to the plastic trim.
  17. Jan 28, 2025 at 9:26 PM
    2TunGet1
    100%. Screws are ugly as sin, all oxidized. They almost look white, lol! I’ll be spray painting them for sure. Really enjoying the process of restoring the old girl. Bought her new in 2000, 25 years!
    DBombs[QUOTED] likes this.
