Doors lock/unlock when wet/washing truck?
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Jul 21, 2024.
  1. Jul 21, 2024 at 12:14 PM
    SDHNTR
    SDHNTR [OP] New Member
    Ok, third time it happened today washing my truck. First time I wrote it off as some odd coincidence. Second time it left me scratching my head but not enough to investigate. This time it's confirmed and I'm puzzled. There is some odd feature that makes the doors lock and or unlock and the mirrors fold/unfold when washing my truck. Spray it with water and the doors lock and mirrors fold in. Then dry it off and it unlocks. Spray it again and it locks. Why on earth? Has anyone else experienced this? It's not the feature alone that bothers me, it's just the fact that more R&D went into something so lacking of reason. Or am I missing something and this does serve a purpose?
    Thanks Toyota for spending more of my money on absolute nonsense rather than building a quality truck!
  2. Jul 21, 2024 at 12:21 PM
    Alden
    Alden New Member
    Your proximity key is too close to your truck when you're washing it. Leave your key in your house and away from the truck when you wash it and this shouldn't happen.
  3. Jul 21, 2024 at 12:23 PM
    SDHNTR
    Key was sitting on a table 10+ feet away.
  4. Jul 21, 2024 at 12:27 PM
    Alden
    Alden New Member
    Exactly. That's too close. Leave it inside the house, away from the truck when you wash it. 10 feet is too close.
    This happens to any vehicle with a proximity key. This isn't just a Toyota thing.
  5. Jul 21, 2024 at 12:28 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    When washing, the water splashing on the inside of the handle activates the lock/unlock same touching it. Move fob out of range.
    Tundrastruck91, SWB Tundra and Alden like this.
  6. Jul 21, 2024 at 12:30 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    So based off of that, somebody could open your doors in the rain when you’re at home?
  7. Jul 21, 2024 at 12:37 PM
    jctmundra
    Northern VT
    It very unlikely as rain water has a resistivity of 20KOhms, where tap water is 1K to 5K Ohms.
    Spartanfam and Black widow TRD like this.
  8. Jul 21, 2024 at 12:41 PM
    jctmundra
    Northern VT
    For the lock/unlock, at least on my '23, you need fob proximity and activate the door handle sensor. I have yet to have the doors unlock just walking up to the vehicle. I have experienced the lock/unlock when fob is within range and washing. Moved fob out of range and is stopped.
    SWB Tundra likes this.
  9. Jul 21, 2024 at 12:54 PM
    SDHNTR
    This is absolute insanity. My key hangs on a hook right inside the garage door. Guess I’ll have to move it. This entire truck is a case study in nonsensical overuse of technology. What happened to Toyota just building trucks that worked?
    So easy to see where Toyota redirected resources with this 3rd Gen. Jumping the shark!
    Fobroader and AZBoatHauler like this.
  10. Jul 21, 2024 at 1:03 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Easy way to tell is put your keys where you want and see if you can manually lock or unlock with your hand. If you can, your keys are too close. For reference if I put my key in my toolbox of my truck, I can’t lock or unlock by hand and that’s only a few feet from the door. 10 feet should be plenty away but maybe the signal is not blocked.
    Alden likes this.
  11. Jul 21, 2024 at 1:21 PM
    Danman34
    Danman34 New Member
    Danny
    I was being facetious haha.
    Alden[QUOTED] likes this.
  12. Jul 21, 2024 at 1:24 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    My FOB rarely leaves my center console. I've never had my truck lock or unlock itself when washing it.
  13. Jul 21, 2024 at 1:40 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    You can disconnect the fob communication with the truck by press and hold Lock and while holding press the Unlock button twice. That should solve the problem of having the fob too close to the truck.
  14. Jul 21, 2024 at 1:53 PM
    Breathing Borla
    Northern Illinois
    that’s kinda a very minor thing to conclude that Toyota doesn’t build a quality truck over isn’t it?
    Mine locks and unlocks when I wash with the fob in my pocket as well, who cares , just keep washing and doing your thing
    my 2023 25th anniversary sienna does the same thing , it’s not a big deal
    and if you don’t want that to happen for some reason, just temp disconnect it like the other fella said here , it’s easy
    now go out and boost with your clean truck and move on from the dramatics , my friend !
    MTRock and chaztizer like this.
  15. Jul 21, 2024 at 2:19 PM
    SDHNTR
    You make a valid point, but this is just one matter on a looooong list of frustrations with the QC of this truck. Plus... I simply would've actually preferred tow hooks over a neato lock/unlock feature while washing my truck! You know, something actually useful?
  16. Jul 21, 2024 at 2:29 PM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    Same thing happened with my two 3rd gen Tacomas. The pressure washer would sometimes unlock the doors or lock them with just the water. Happened on my tundra to when I washed it before
  17. Jul 21, 2024 at 3:15 PM
    Alden
    Alden New Member
    Every modern vehicle allows this to prevent accidental lockouts.
    Terndrerrr and chaztizer like this.
  18. Jul 21, 2024 at 3:19 PM
    SDHNTR
    How does a feature where it locks and unlocks itself when sprayed by the hose prevent lockouts?
  19. Jul 21, 2024 at 3:25 PM
    Alden
    Alden New Member
    I'm speaking to the guy who leaves his fob INSIDE his truck.
    You have your fob OUTSIDE your truck, but in too close proximity when you're washing your truck.
    This isn't that difficult to comprehend, gentleman.
    Terndrerrr and 75tranzam like this.
  20. Jul 21, 2024 at 4:03 PM
    SDHNTR
    I disagree. I think it’s rather difficult to comprehend why my truck locks itself when sprayed with a hose. That literally makes zero sense.
  21. Jul 21, 2024 at 4:08 PM
    Alden
    Alden New Member
    Move your key fob about 5 feet further than where it currently sits while you're washing your truck, and everything will be fine.
    My 2014 Grand Cherokee did this. My 2018 Tacoma did this. My 2023 Tundra and every new vehicle with a proximity key fob does this.
    Your handle is sensing your spray hose, thinking it's touch from a hand attempting to lock or unlock your truck because your fob is so close to the truck. That's how fobs work.
  22. Jul 21, 2024 at 4:22 PM
    DRP
    DRP Old Member
    Dave
    This is mentioned in the manual along with other things that can affect locking/unlocking.
    Alden likes this.
  23. Jul 21, 2024 at 4:41 PM
    SDHNTR
    I’m sure you’re right. But it doesn’t change the ridiculousness of it. Personally, they could keep the water pressure sensing fob and given me a simple key that you turn to start, if it meant that in trade I get back: tow hooks, Skid plates that aren’t plastic, wheel wells that aren’t fabric, actual door and window gaskets that seal, brakes that don’t scream in the morning, a windshield that isn’t distorted, a real transmission cooler, motors without metallic sand, etc. I miss my 2017 4Runner, and the 99 before it, and the 88 before it, and the 76 FJ40 before it. No nonsense, just reliability and utility.
  24. Jul 21, 2024 at 6:34 PM
    jctmundra
    Northern VT
    See post #8 tap Water is about 1K ohms, the resistivity across a human hand is around 1K ohm {everyone is little different} . 1K ohm trips the sensor, tap water or hand. Has nothing to do with pressure. . Simple and it works.
    Alden, Outbreak444 and MTRock like this.
  25. Jul 22, 2024 at 5:14 AM
    Matt2015Tundra
    2023 1794 CrewMax
    This was my point. The OP could just leave his FOB in the truck while washing it, or move it further away, and not have to deal with the horrific locking/unlocking ordeal. :rolleyes:
    Alden[QUOTED] and TundraMoe like this.
  26. Jul 22, 2024 at 5:28 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I know that this is a Gen 3 discussion but.... My 2021 has this same problem.
    If you leave the key in the truck everyone gets a sound show because it keeps audibly telling me that the keys are in the truck.
    If I keep them in my pocket the truck locks and unlocks periodically the I get water on the door handles in the right way.
    I suspect that this happens because the Tundra's handles are tuned to work with gloves on.
    My other cars do not do this but they either have a button on the handle or struggle to work when I have gloves on.
    Tundrastruck91 likes this.
  27. Jul 22, 2024 at 6:30 AM
    jctmundra
    Northern VT
    See post 8 & 24. Handles are calibrated to the resistivity of a human hand.
  28. Jul 22, 2024 at 7:01 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    These are capacitive sensors. They do not require skin contact.
    This is a known problem with capitative technology. It can be overcome but there is a cost and there are some drawbacks. I believe that the majority of the automotive world has let it be and most of us just move our keys.... We want the feature but not willing to pay enough for it to eliminate these relatively minor issues.
    I would be willing to bet that the truck reacts similar in a rain event but it takes a lot of rain to be similar to the hose being sprayed on the side of the car and nobody is there to see it or our keys are far enough away most of the time to not be a problem.
    Some quick research:
    https://www.eetimes.com/capacitive-...capacitive proximity,car key transmitter (4).
  29. Jul 22, 2024 at 8:12 AM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    I wonder if the doors unlocking from washing with the fob nearby was one of the demerits in the consumer reports rating posted in the other thread?
  30. Jul 22, 2024 at 8:15 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Feels like ever since the recall, we've been infiltrated by CR writers in here...buncha ginas
