Downstream o2 sensor replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Mikes Tundra, Apr 23, 2024.
  1. Apr 23, 2024 at 3:13 PM
    Mikes Tundra
    Mikes Tundra [OP] New Member
    I need to replace the downstream o2 sensors on my 03 tundra. The upstream ones were done 30000 miles ago. Any tips or suggestions..I'm mechanically familiar with the truck, but I'm wondering if I will need to put heat on them to break them loose ( I don't have a torch). They are original 160,000.
  2. Apr 23, 2024 at 3:57 PM
    aredub
    aredub Supply Chain Guru
    USA
    2001 Tundra SR5 AC 4.7 2WD
    King Coilovers, Pro Comp Wheels, BFG KO2s, Kenwood head unit
    I’d say not likely. I’m at about 130k and just flipped mine from side to side yesterday due to low voltage on one side. Two 12mm nuts per side and the sensor clip that you’ll have to undo. The clips were more of a pain than anything. Hopefully this won’t be too big of a deal for you.
  3. Apr 23, 2024 at 5:11 PM
    Whether you need heat/penetrant really is a matter of where you live and how many miles on the truck.
    I know it's not in everyone's budget, but I always recommend replacing them in upstream/downstream pairs. This is one of those parts you want to use Denso brand (OEM off-market), and be careful to look up your part numbers for "exact fit" sensors at www.densoautoparts.com, noting that RWD and 4WD trucks sometimes use different sensors.
    ChesterTundra likes this.
  4. Apr 23, 2024 at 6:22 PM
    Mikes Tundra
    Thank you
  5. Apr 23, 2024 at 8:45 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Pics? If the nuts look half disolved from corrosion, a nut splitter might be a better idea. That’s what I did with my first set.
    The 2nd set still had plenty of the nut left, so I spun them off with an impact gun and a universal wobble extension to get the socket in there.
  6. Apr 24, 2024 at 9:46 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I need to do this on my last remaining original downstream. I'm worried that the "shield" around the sensor would be in the way of a splitter. Do you remember what yours looked like/still have it?
  7. Apr 24, 2024 at 11:43 AM
    Jack McCarthy
    Bill
    North of Boston
    IIRC, I did what I could with a nut splitter and cold chiseled the rest. Most of it was dissolved already. Didn't even resemble a nut IMO.
    The 2nd time around, I got rid of those "shields" as they only get in the way. Hasn't caused any issues yet, but I don't go off-roading regularly where a rock might hit them. BTW, if you mangle the threads, you can get another stud to put in it's place. I had to do that the first time. It doesn't have a part number but the dealership is generally able to match it if you bring in the old one.
  8. Apr 24, 2024 at 11:47 AM
    NickB_01TRD
    Nick
    KY
    Hmm I suppose I could just go old school with a sharp chisel. There isn't much left on the one that's holding me back. The other nut on that sensor had dissolved completely. I got the ones on the other sensor with needle nose vise grips but haven't had any luck with the other side.
    I got 3 sensors done and have no check engine light so I've just been letting it ride.
  9. Apr 25, 2024 at 2:44 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    When I had to do this, the nuts on the downstream sensors had pretty much disintegrated. In fact, the reason it was throwing a code at all was because of a leak between the sensor and gasket that opened up after the nut was gone. I used a small Dremel cut off wheel to remove the remaining bit of nuts. Miraculously, the studs were still good, although I did have to chase the threads a bit.
    Jack McCarthy and Tundra2 like this.
  10. Apr 25, 2024 at 3:24 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    same here on my 2002. Ran a die down the studs to clear any other debrizzle, and then put stainless hardware (Nut, lock washer, and flat washer) where mild steel had only gone before
  11. Aug 24, 2024 at 1:36 PM
    John TRD helena
    John TRD helena New Member
    2001 Tundra sr5
    I'm having the same issue with the rusted hardware on the bank 1 downstream sensor. Those are removable studs?
  12. Aug 24, 2024 at 4:07 PM
    Jack McCarthy
    Bill
    North of Boston
    Yes.
    shifty` likes this.
  13. Aug 25, 2024 at 2:49 PM
    socomoby
    socomoby New Member
    2006 DC V8/2WD SR5 LSD
    I agree. I will say though, could have been only me, but the upstreams are a bitch. Especially the drivers side one.
    shifty`[QUOTED] likes this.
