Dreaded 1st Gen Bilstein 5100 Q&A again
Discussion in '1st Gen Tundras (2000-2006)' started by socomoby, Jan 25, 2024.
  1. Jan 25, 2024 at 3:25 PM
    socomoby
    socomoby [OP] New Member
    2006 DC V8/2WD SR5 LSD
    Hello all. I’ve been lurking for quite a while but have recently acquired a 2006 DC 2WD. The previous owner installed a rough country 2.5” lift (struts, 2 inch blocks rear, front hockey pucks)
    I wanted to remove the kit and go back to stock in the rear. I had a few questions as I could not find answers to these specifics :
    Did the truck have rear blocks or did the u bolts just sit on the spring leafs?
    Using Bilstein 5100s up front, what setting should I use to level the truck off if the rear is in stock position?
    When going back to stock in the rear outside of “stock” u-bolts, are there any tips or things to watch out for?
    Thanks to all!
  2. Jan 25, 2024 at 3:31 PM
    Depends on the truck. Some had a spring seat, some had a pinion wedge also, to pitch driveline angles properly.
    Depends what you choose for springs. Are you sticking with the factory OEM springs? Or going with a lifted spring?
    You should look into whether your truck had wedges or not, and which way the wedge faced.
    Do not re-use U-bolts (but sounds like you may already know that).
    Always tighten down your four bolts on the seat evenly, in a criss-cross fashion. I like to get the bolts down with roughly three threads showing on each bolt, then do, like, 5 half-turns each, then 4 half turns each, then 3 half-turns each, then 2 half-turns, then rinse-repeat with two half-turns until they're all equally tight. Then torque to spec.
    Did you read the Suspension/wheel/tires section over here? It gives a shedload of info on lifts for these trucks.
    JasonC. and HBTundra like this.
  3. Jan 25, 2024 at 3:53 PM
    socomoby
    Thanks and hello Shifty.
    They’re aftermarket coils from the kit, but I’m 99% they are standard OEM size. Not a lift coil.
    How do I confirm whether it is a spring seat or piñon wedge? If a piñon wedge, how do I proceed back to stock?
    I will definitely check out the link to the suspension forums. Thanks
  4. Jan 25, 2024 at 4:03 PM
    Not the suspension forum. Just the suspension section of that thread I linked. The suspension forum guys probably aren't going to help.
    I think the wedge was dependent on your specific truck model. And maybe it was just an earlier model thing, I can't remember. I saw it in one of the Toyota exploded diagrams for our trucks a while back. I think it was either tied to 2WD vs. 4WD or maybe it was trucks with TRD package? I honestly cannot remember.
  5. Jan 25, 2024 at 6:58 PM
    socomoby
    Got it. Thanks.
    Also from my research, looks like the pinion wedge/shim is a 4WD thing
    shifty` likes this.
  6. Jan 25, 2024 at 7:03 PM
    Yeah, is one of those things ... I can't always remember :D
    Too many small things with these trucks!
  7. Jan 26, 2024 at 3:15 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Spring perch 3 will give you level with slight nose down rake, assuming stock-like springs.
    FrenchToasty likes this.
  8. Jan 26, 2024 at 5:34 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    06 DC SR5 2WD here and just put Bilstein 5100s on mine raising at 1 inch in the front and adding a 1 inch block in the back.
    the springs sat on a little shelf for lack of the proper term. It had a nipple that fit into a hole on the springs to keep it in place. The block I had had a hole to fit on that nipple and then it's own nipple to accomplish the same thing
    all that to say nothing special there to worry about - just follow shifty's advice
  9. Jan 27, 2024 at 6:56 AM
    socomoby
    Awesome. How did your install fair? I had a hell of a time compressing the spring. So much so that I had to settle for the perch rung 2nd up from bottom and not third like I wanted. Heck, I still had the other side to do today. It took almost 2 hours to release the installed strut because the mount bolt got caught sideways in the LCA and the spring was being a jackass
  10. Jan 27, 2024 at 7:03 AM
    This is where your bottle jack is handy. Put your factory bottle jack under the LCA and use that to lift/support the LCA to a level where the bolt will come out easiest. Unless it needs to go the opposite way, in which case you need to step on the LCA while tugging at the mount bolt.
    But of course, this assumes you didn't do something generally stupid, like leave the swabar links attached.
    Riverdale21 and Weagle like this.
  11. Jan 27, 2024 at 7:54 AM
    Weagle
    Prattville, AL
    I complained about it and said I wouldn't do it again but I would. it just took longer because it was my first time dealing with suspension. And I learned to have the right tools. I've never worked with suspension and I trusted the local loan a tool to give me the best tool, but they did not
    I had my coil springs pre-installed. Same thing applies. However, if I was going to do that myself, I would opt for a higher end tool and spend $100 or more extra Just safer, easier and worth it for me
    shifty` likes this.
  12. Jan 27, 2024 at 8:14 AM
    Riverdale21
    OTP ATL
    I've had great luck with this type of spring compressor. It still feels like you're handling a time bomb when the spring is compressed. But a time bomb with a less sensitive trigger.
    The spring compressor "ears" on this type of tool wrap around more than half the spring. Feels a lot more secure vs the loaner tool narrow "fingers".
    https://www.amazon.com/stores/8MILE...ool/page/D6797A84-A5A4-49EA-A831-5742647C4AE3
    Weagle likes this.
  13. Jan 27, 2024 at 8:31 AM
    socomoby
    Interesting. I used the clamshell style
    Weagle likes this.
  14. Jan 27, 2024 at 8:56 AM
    socomoby
    Lol I loosened them. Once I finally got it out I realized it may have been n best to remove them all together
  15. Jan 27, 2024 at 9:59 AM
    Yeah, you can't get the range of motion you need very easily unless you fully detach one swaybar link. Always detach the swaybar when installing struts or control arms.
    For similar reason, when you lift, you really need to install an extended link, else you will not only limit travel, but can end up with clunks/thunks/knocks related.
    Weagle likes this.
