Drive Shaft Vibration
Discussion in '1st Gen Tundras (2000-2006)' started by duncanrc, Apr 3, 2019.
  1. Apr 3, 2019 at 6:40 PM
    duncanrc
    duncanrc [OP] New Member
    Duncan
    2014 SR5 Double Cab 2WD 4.6L
    Hi
    My centre carrier bearing was recently replaced at 260,000miles.
    My truck did not suffer from any noticeable vibrations.
    I am told all other joints are in good working order.
    After my first drive I discovered a vibration.
    My mechanic noticed he had not assembled it correctly. So he did.
    However the vibration, although now different is still there.
    Are there any marking to be sure? I have read there are none...
    This video does show alignment marks. Are they to be seen in 2wd tundras?
    https://www.youtube.com/watch?v=O27wUPdUkdM
  2. Apr 3, 2019 at 6:52 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I'm pretty sure your are supposed to Mark it before removal so you can reinstall the same way . At least that is how I was taught
    JohnLakeman likes this.
  3. Apr 3, 2019 at 8:09 PM
    duncanrc
    Duncan
    Yes my mech did. However he did not adhere to his marks on assembly. I think his partner reassembled.
    He did have to perform a full uninstall and reinstall of the driveshaft with his previous marks all aligned.
    However the vibration persisted but at a difference speed.
    Are there are any marks from factory?
    ps; Pics are from the above vid
  4. Apr 4, 2019 at 3:55 AM
    Professional Hand Model
    Hand Protectors
    There should be factory marks still present. The 02’ still has the originals which were done with some kind of yellow marker.
  5. Apr 4, 2019 at 4:26 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did they also rebalance the drive shaft? This is done on a special machine that not all shops have.
    Edit, it really sounds like they did something wrong and potentially don't have the skills to fix it. They either need to make it right or give you a refund so you can pay someone else to fix it.
  6. Apr 4, 2019 at 9:33 AM
    Cacoleman2014
    Cacoleman2014 New Member
    Louisiana
    2006 Tundra SR5 double cab
    I replaced all of my joints and bearing and still had a vibration. Ended up replacing driveshaft after one of the joints failed and ruined the end. It was unreal how much vibration went away. It was definitely unbalanced.
  7. Apr 4, 2019 at 11:36 AM
    duncanrc
    Duncan
    Well that is too bad you had to go to that extra cost Coleman.
    However I had no vibration at all beforehand. Even with a shot center bearing.
  8. Apr 6, 2019 at 9:07 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Sounds like one of your u joints is bad . Or perhaps the new center bearing.
