Driver power seat not working
Discussion in '3rd Gen Tundras (2022+)' started by 559Tundralona, Nov 16, 2023.
  1. Nov 16, 2023 at 12:29 PM
    559Tundralona
    559Tundralona [OP] New Member
    Alex
    Fresno
    2023 Ice Cap Tundra Limited TRD OR Hybrid
    Diamondback switchback Eibach Pro-Lift Rays Gram Lights 57DR-X 17x8.5 +0 YotaLEDS grille lights Tufskinz overlays
    As the title states, I got my Tundra this past August. Only time we adjusted the driver seat was when the wife an I first got the truck and set the memory settings. Since then we had not touched the power recline or lumbar until recently. We noticed that the seat will not recline and the lumbar support will not work. The seat does slide though, has anyone had any issue with their power seats? Passenger seat work perfectly fine.
  2. Nov 17, 2023 at 12:51 PM
    matthinkle
    matthinkle New Member
    Lighthouse Point, FL
    2022 1794 Hybrid
    My thigh extenders stopped working. Not a big deal since I don't really use them anyway. I took it to the dealer and they told me something was unplugged. They now work fine. Don't know if that will help you at all.
  3. Dec 8, 2023 at 4:30 PM
    559Tundralona
    Alex
    Fresno
    Finally got the truck in for service and as you stated one of the clips came undone. Thank you for the reply. :thumbsup:
  4. Jan 23, 2024 at 10:01 PM
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    The front leg extension on my platinum seats stopped working within the first week I had the truck. I made a warranty appointment but the dealer couldn't get me in for over a month. Finally went in today and they said the front extension motor was bad but they can't just order that little motor. Apparently the motor comes on the whole lower seat track as one piece but it's back ordered for a while. They've had to do one other one just like this before. I don't use or need the front extension but nonetheless I want everything working on a $65k truck. Just thought I'd report for anyone else with the same issue that the whole seat track has to be replaced.
    TallulahTundra likes this.
  5. Jan 24, 2024 at 10:12 AM
    Hunter1699
    Hunter1699 New Member
    Mine did the same thing and front leg extension worked like twice. Had it replaced and the whole base frame had to be replaced. Took a couple of weeks to get the part in and an 1.5hrs. All good!
    TallulahTundra and Hoody like this.
  6. Jan 25, 2024 at 1:18 PM
    rlc177
    rlc177 Data Logger
    Northeast PA
    I've had the thigh extender get stuck as well, I'm not sure why this hasn't been tsb'ed already. In my case I found I could get it to work by tugging it outward while pressing the extend button. Seems only to get stuck if you leave it fully in for a long time. I've left it slightly out always and its 100% now. I'm thinking they are parts cannoning the issue and probably don't have the root cause yet.
    Jettster likes this.
  7. Jul 24, 2024 at 8:05 AM
    TT2024-Lunar Rock
    TT2024-Lunar Rock New Member
    I just purchased my 2024 TT Platinum.... same thing has happened after 3800 miles. Brought to dealership on Monday worked for about 5 minutes and then stopped working again. Dealership told me I am not pushing and holding the button. Not true. Rest of the seat works fine. Just sent a video using my mobile phone and texted the service rep again. Very frustrating not having the leg/thigh extended especially for long trips. Side note - not as bad as my issue with the passenger front door where the lock kept flickering and making a loud noise and would not lock. This was repaired when the service mechanic said the lock was stuck and not an actuator. Lastly, the TT truly is an excellent vehicle with a very smooth ride.
  8. Jul 24, 2024 at 8:36 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  9. Jul 29, 2024 at 8:15 AM
    TT2024-Lunar Rock
    Crazy - went back to dealership to fix the thigh extender after making numerous videos to show them. On the way to dealership on Friday it worked. Technician said everything was fine. Left the dealership and after a few hours stopped working all weekend. Very strange, especially since the dealership tells me there is nothing they can do unless I pull in when its not working. Any thoughts on how to fix this issue myself?
  10. Jul 29, 2024 at 8:27 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    The PDF document in post above yours shows how to fix it. T-SB-0053-24
    c&wsinbad likes this.
  11. Aug 29, 2024 at 10:31 AM
    Bean's Capstone
    Bean's Capstone New Member
    2024 Toyota Tundra Capstone
    Hey Guys - been struggling with this issue on my Capstone purchased 5 days ago ! Intermittent operation of the leg extension button. I am scheduled for service to apply T-SB-0053-24 as well. MST claimed it is a certain fix but they will have to pull out the driver side seat entirely to insert the new o-ring.
  12. Aug 29, 2024 at 10:55 AM
    TT2024-Lunar Rock
    Well long story short. Drove my brand-new TT Platinum to the dealership while it was not working. They ordered a new frame and motor. The entire package to fix the lumbar issue. Thought this was done correctly. Drove off and just tried to use the lumbar for my thigh for a trip from Augusta to Raleigh. Stopped working once again. Please call Toyota Customer Service asap if you are having the same issues. I called my local dealership once again and waiting on a call back. I have had Toyota's since I was 26 and now in my sixties and never had any real issues or concerns previously.
  13. Oct 15, 2024 at 6:16 PM
    BigTrout
    BigTrout New Member
    2024 Tundra Platinum TRD Off Road
    Just had mine fixed today. They installed a “spacer” . Seems to work great now (so far).
    part 72135-AN010 - Spacer, Fr Seat Trac 1
    Tundrastruck91 likes this.
  14. Oct 16, 2024 at 8:00 AM
    TT2024-Lunar Rock
    BigTrout - thanks for sharing the "spacer". After speaking with Toyota headquarters, they reached out to my local dealership again and now have another appointment next Wednesday. Even though the dealership replaced the motor and casing they now believe it is an electrical issue, switch, or bad OEM motor. I will share the spacer and part number with them. According to T headquarters there is no recall or other complaints.
  15. Nov 4, 2024 at 11:00 AM
    TT2024-Lunar Rock
    Big Trout - the dealership took your suggestion and part 72135-AN010 - Spacer, Fr Seat Trac 1.... and so far it works perfectly. Thanks!! Roger
    BigTrout likes this.
