Driver Side Door Lock Stuck
Discussion in '1st Gen Tundras (2000-2006)' started by Seabass18, May 7, 2024.
  1. May 7, 2024 at 2:14 PM
    Seabass18
    Seabass18 [OP] New Member
    Sebastian
    Boise, ID
    2000 SR5 AC 4x4 4.7L
    Hello,
    Wondering if anybody has stumbled upon this same issue. The driver side door lock won't turn left to lock the vehicle, it feels like the left position is stuck, however, the right position does work and unlocks the vehicle. It's worth mentioning that the key works perfectly fine on the passenger side in both directions, lock and unlock.
    When locking the vehicle, I lock it from the inside with the door lock switch.
  2. May 7, 2024 at 8:36 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Lock cylinder may be dirty inside.
  3. May 8, 2024 at 1:55 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I had difficulty operating my doors with a key (and sometimes the ignition too). I went to the dealer and had them "cut a key to VIN" and now everything works fine. Turns out that the keys I got with the truck were copies of copies of copies, and worn as well
    Weagle likes this.
  4. May 8, 2024 at 8:43 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Get some silicone spray and the little red straw. Shove the straw in there and give it a shot or 2. Put in your key and work it in and out and gently turn it. Repeat until lock will turn easily.
    you are trying slowly unbind and slowly work in the lubricant. You don't wanna go crazy and snap the key.
  5. May 8, 2024 at 8:48 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. May 8, 2024 at 12:35 PM
    This is the exact bottle I had, I just did my locks last week. You'll need a small flathead driver to pop open the key door so you can blast graphite in. (The tube works as a pump)
    1lowlife[QUOTED] likes this.
  7. May 10, 2024 at 3:51 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    That the same one I use too.
    shifty` likes this.
  8. May 10, 2024 at 4:20 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    My fuel door lock seized up and I couldn't turn it. I tried powdered graphite and it still didn't turn, so I shot a little WD-40 in the slot and the solvent action immediately freed it up. Next a shot of plastic safe contact cleaner, then after the contact cleaner cleaned the WD-40 out I again douched it with the graphite. Turns nicely now and I can again add fuel. That's important you know.
  9. May 10, 2024 at 5:23 PM
    It may be someone used a liquid lubricant previously. Graphite works best (may only work at all) on dry gears, it's a dry lube.
